20 Most Recent
D-Link DIR-628 Wireless Router Questions & Answers
My router won't even turn
need info... is it DOA (Dead On Arrival)? did it happened after a power loss? or all of a sudden? you should first check the AC adapter for power with the use of a multimeeter, try plugging it in a differant outlet, then you could try performing a reset (according to manual instructions) but it could be just dead... these things happen
Sorry!
How to get a user manual
Go to the D-Link support section of the website and look up your model, and you should be able to download manual and set-up guides as well as firmware updates.
Computer wont connect to dlink. i can directly so
First check your LAN cable between the router and the internet modem. Try a new cable. Reboot the router.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Output power
Try a reboot first. If his does not work do factory reset. This will erase all your information and you will have to set-up all your functions, but often this is the solution to most issues with any router.
Why is the globe on my D-Link DIR-628 have a steady orange light?
The orange light usually means that you are not connected.
Try this:
Step 1: go to your Windows command and type ipconfig /all, it will give you all the vital information, i.e. default gateway, dns server, ip, etc.
Step 2: Go to your browser, type 192.168.0.1 (default ip address for the router)
Step 3: Go to the Setup Tab, click on Internet Connection Setup Wizard, if you feel adventurous, select the manual internet connection setup and fill in all the information that it ask for. The wizard should be straight forward.
Step 4: Go to the top and Save Settings, it will prompt you if you are sure, click ok and the router will reboot and apply those configurations and the orange led light will turn into a green one.
How do i turn my
Select 2.4GHz if you want to use the 2.4GHz band or 5GHz band if you want to use the 5GHz band.
The product Manual is located here:
http://www.dlink.com/products/default.aspx?pid=DIR-628&tab=3
(Page 29)
D-Link problems
open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway, it should be your IP address.If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping 192.168.0.1', hit Enter. If your PC is receiving connection from your router device, you will see a message like Reply from 192.168.0.1: bytes etc. If there is no connection, you may see the Request timed out message.The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device. If you need any kind of technical assistance you can contact
support cell at here
How do i change my username for dlink
Are you talking about the SSID which is what you see when you connect to
the wireless network? If so you will need to go inside the router and
under the Wireless Settings change the SSID.There might be an ip
address on a sticker on the router that will tell you how to get into
it. If not check your documentation. Basically you are looking for
something like 192.168.0.1 that you will put into the web address of
your internet browser.Check your user manual because you will
also need the user id and password to get into the router. If you don't
have the user manual, get it from the manufacturer's website.
Get
online
and got to www.google.com In the google search box type: "Dlink
Support" (without the quotes and put your manufacturer name before
Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals on the site. It will tell you
what the ip address is and the default user id and password.
