20 Most Recent
Belkin F5D9231-4 Router Questions & Answers
Belkin N Wireless Router
If your internet provided suspects your using a router to lead to more than once pc - it cost them bandwidth - that said - you must call your provider. Ask them if you need to use a 'keep alive' setting. Belkin is SUPER at helping you set up your unit as well.
Ask the ISP - Internet Service Provider about this. As it is the DSL losing it- the Dynamic mean - changing and they are pulling the signal to save money.
Not sure if router is
Go to the settings menu, then Network, If the Roku sees your network all you have to do is put in the WEP key to connect to your home wireless network. If the Roku does not see your home network try moving the router or the Roku away from any heavy metal in the room, (ie fireplace, or objects). Hope this helps FixYa up.
I forgat my password and i can not used as
Look at the back of the router. There should be a reset button. Press it or use a paper clip to poke the hole for a few seconds until it gets resetted. The router would be completely reset to factory settings.
My wireless N router is not recognized at my pc .
You can try the following steps..
1) At the back/base of the router there will be a small hole/button as reset..press and hold it using a tooth pick or paper clip and hold it for 10 seconds..disconnect the power from the router and connect it back after 10 seconds and check whether the setup page works.
2) If the above step doesn't work press and hold the reset button for 40 seconds..after 40 seconds while still holding the reset..disconnect the power cable(keep holdin the reset) and connect the power back after 40 seconds(While still holdin the reset) and then let go of the reset button disconnect the power for 10 seconds and connect it back and check if the router setup works.
The wireless light will be lit only after a computer is connected to your wireless network. If the above two steps didnt work it looks like the router may be fried. You can get it replaced from Belkin as they have lifetime warranty on this product. The number is 1800-223-5546.
Hope this helped.
Where is your NAT configuration to open and close
Belkin uses the term "Port Forwarding" in the "Firewall" section of the configuration web pages instead of the term "NAT".
For each port that you need to forward to the PS3, create a separate entry in the "Virtual Servers" section.
If that's too much work, then determine the private IP address of your PS3 and add that address to the DMZ for your router. The DMZ settings area is also in the "Firewall" section of your router configuration web pages.
For more information, go to the Belkin support web site and select "G" for "1" and "F5D9231-4" for "2" and the select either V2000 or V1000 depending of your router version (see the bottom of the router) and download the user manual.
While you are there, check whether there is a firmware update for the router available.
I have a Belkin N+
Which Operating System on that laptop with the issue? Is there any firewalls? Did you try to move it to another LAN port and see whether it will work? Is there any settings in the browser about security or proxy which might cause some issues? I will post more if you give me more details.
My belkin g router F5D9231-4 is not allowing me to
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Wireless inop says its connected showing full
In case there are many WiFi signals in your area, try changing Belkin's channel at another one, because it's limiting down the speed in order to keep the connection alive.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
I cannot find my WEP key on Router N with Belkin.
You changed the network key.
Make sure that you will connect your computer to the router with the cable to change the wireless settings of the router.
Do not change the wireless settings of the router using the wireless computer.
open the set up page of the router and check the wireless settings.
Change the name of the wireless network also.
create a new network and try to connect to the new wireless network.]
I think you did not change the name of the network and your computer might be trying to connect to the same old network name with the old settings.
Click here for more information about router and networking.
Got a new laptop and can not connect, I put in the
When filling in the security code, it is usually asking for a WEP key. This is usually found on the back of the router itself. They usually have a 10 character alpha-numeric code. If your computer is asking for 12 digits, enter two zeros infront of the code listed on the back of the router and try it again.
Hope this helps
Belkin router wireless is good with green lights
HI! I believe your having an issue with the connection. if the modem light is flashing. try to unplug the power of the modem for 1min and plug it back in. if still flashing, press the reset button for 20secs. then release, it will turn of and on. after it initialize, unplug the power from the modem for 20secs then plug in, if its still the same, call your isp provider. modem is dead
I need the default password so i can set up a
The f5d9231-4 ships with the password blank, so if it's requiring a password and you don't know it, you'll have to reset it to factory defaults. Before you do this, you should make sure you have the various settings you need for your particular ISP because the factory reset will wipe all the settings.
The reset button is either on the back or the side of the router (there are two series of this model number). Press and hold the “reset” button for at least 10 seconds, then release it. You may have to use a paperclip to depress the reset button. The lights on the Router will momentarily flash. The “router” light will begin to blink. When the “router” light becomes solid again, you will have completed the reset.
My laptop connects to the router but the internet
Greetings,
If the laptop is hooked up by ethernet cable and the problem happens when you move the laptop, you either have a bad ethernet cable or a bad ethernet port in your laptop.
Probably the best thing to do in your situation is since you have a wireless router, enable wireless on your laptop and use that instead and work wirelessly.
Let me know if you need help setting it up.
