20 Most Recent
Acomdata E5 HD320UHE5-72 320 GB USB 2.0 Hard Drive Questions & Answers
Lights up, makes skipping sound, wont show up on
Sadly, that skipping sound is most likely the sound of death for your external hard drive. The drive is composed of two or three disks, with read heads that hover incredibly close to the spinning disks. That skipping sound could be the head scratching the disk, leaving the hard drive useless. Your best bet is to contact the manufacturer and have it replaced as defective - if it's still warrantied.
External Hard Drive won't respond
ok 1. you need to be sure that you can`t have acces anymore by usb to the external HD... try in another machine example a other laptop.. or you need to open the HD and connect to other way with a new conector that sell in comusa or other computer store... pls click that my solution was usefull
I have a model HD320UHE5-72 external acomdata hard
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Unit powers up and attempts to connect to pc,
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
You should also do this to cheack the drives connections are not bad inside the enclosure
