20 Most Recent
LaCie d2 SAFE 500 GB FireWire 400 Hard Drive Questions & Answers
My lacie does not show files anymore why?
If the external hard drive was unplugged during a file transfer or without using the Windows "Safely Remove Hardware" utility, there might have been data loss.
If you have a second machine, try plugging the drive into it and see if you can read the drive.
Also, try transferring a file onto the drive, unplug the drive, plug it back in and see if the file is still there. If it's not there, it could point to a problem with the cable. Try to use a different USB cable and perform the same test.
If none of those suggestions work, the drive could have gone bad. It's not uncommon for hard drives to become unreadable due to bad sectors, or mechanical failure. You may need to purchase a new drive.
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
