Read the instruction manual carefully. If you are certain it isn't working as it should then don't hesitate and tell the supplier it is faulty and to send a replacement or give a refund.
Go to hardware and get at most 1 size (3/16 up to 1/4) larger screw and a square washer and a lock tooth washer on the back side of the dryer and then re-tighten the new screws. Also, while you are at it, adjust the legs on all four sides to level the dryer, they simply screw in or out as needed. If you don't have a level get a plastic coke bottle and fill i/3 full. Put a board of yard stick on the machine from side to side, lay the bottle on it and adjust unitl the water is level, then do the same front to back..
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model. I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try. FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs. If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
(really try this first!)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0) Doesn't matter whether it is empty or not but switch it off then- very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice. Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up! If this corner did not rock do the same to the other. Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Methinks you need a manual!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
stackable washers i can say from experience are not any fun to work on everything is so compact so well start with giving you this link which you can familiarize yourself with the inside of the machine http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-41791702001/0582/0152000?pathTaken=
and if you look under this section http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-41791702001/0582/0152000/R0112513/00005?blt=06&prst=&shdMod= at part number 43 you will see the pump i dont think that your pump is broken just maybe some stuff either stuck in the pump or stuck in one of the hoses that go to the pump when a pump goes they just stop and dont do anything but yours you said is working somewhat so first question i have for you is are you doing the repair or hiring a technician because this does involve soome electrical and some plumbing skill in order to clean out this hose and pump assembly please right me back i await your reply and if you have any further questions please message me back with them as well please also remember to rank how this opinion has helped iin your appliance situation Thanks again
Rick
You are right....there are steps that you need to follow to
replace the belt in your dryer. Please check this video which is a common one
for Whirlpool/Kenmore Dryers:
Hope this helps...please post back for further assistance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing. I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information. RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell. In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#@#$%
It appears your lid switch/door latch has failed in this instance.
Check the Vibration damper rods to be sure that... 1. They are there and mount is solid. 2. If they are broken in 1/2. 3. The plastic knuckle mounts are not missing/broken. 4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
It appears your button has failed in this instance.
