20 Most Recent
Sabrent TV-PC85 PC to TV Converter Box Questions & Answers
The Sabrent TV-PC85 converter box does not work
That is for converting the VGA output to TV formats. The box is powered via a USB cable. You also need to use the keyboard command to output via the VGA connector - varies among laptop manufacturers, but is usually a function key mixed with the F1-F12 at the top of the keyboard.
How do you install a
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the
back of TV-LCDHR. Plug in the power supply. You should now see a red
light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on
your Cable TV service. When it's done, use the remote to change channels
and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality,
we recommend using a pair of amplified stereo speakers. Connect them to
the "Audio-Out" port on the side of TV-LCDHR.
I connected box to my
the refresh rate of the tv is not capable of reading the output of the box, or your refresh rate settings on the computer are too high for the tv
The product I purchased is
First, Sabrent PC to TV Converter Box is the same as the Sabrent TV-PC 85 TV to Converter Box.
As the Plug comes out of your PC and enters "IN" of the converter box, your Converter box will then go from Video "OUT" to Video "INPUT" at the back of the TV. Use RCA cord, that is, the yellow wire amongst the Yellow, white and red RCA CORD. Once its connected, select "AV" on your TV.
Lastly, set switch 2 to ON in your application.
Good luck.
My .computer has a vga output ,tv has rca- red,
Looks like it should, it supports s-video (same as component yellow) in both PAL and NTSC. For the sound you'd need a 3.5mm jack to component left & right adapter, which probably cost pennies on ebay.
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
