20 Most Recent Kenmore 74612 Gas Dryer Questions & Answers
DRYER TIMER WILL NOT ADVANCE UNTIL PROPER TEMP IS REACHED.TRY IT ON TIME CYCLE.DOES IT HEAT ?IF NOT REPLACE THERMAL FUSE AND TSTAT MOUNTED ON BLOWER HOUSING .REMOVE REAR PANEL OF MACHINE TO ACCESS THIS..~COST $35+
Kenmore 74612... | Answered on Dec 12, 2009
  • Defective heating element
  • Defective related control circuitry
Kenmore Dryers | Answered on Dec 05, 2019
Contact Sears for assistance. Online web site did not show that model, so you may need for assistance if model is no longer available.
https://www.searspartsdirect.com/search?q=630-12902312
Kenmore Dryers | Answered on Nov 25, 2019
Without knowing which model you own, https://www.google.com suggests possible problems, which may involve paying a service technician to identify and replace a faulty part.
Example:
https://www.searspartsdirect.com/diy/article/electric-dryer-wont-start-troubleshooting-video
call tech with gas tkt
Kenmore Dryers | Answered on Oct 21, 2019
The F-22 error indicates that the thermistor that detects the exhaust temperature has failed. (Sometimes the wiring between the thermistor and the control board will be faulty.) Sometimes the issue can be triggered by cold if the dryer is in an unconditioned space.
Unplug the dryer and access the wiring and thermistor. Check the wiring harness connections. Use a voltmeter to check the resistance across the thermistor. At normal room temperature, the resistance should be about 10,000 Ohms.
I hope this helps. Please add a comment with the model number (including the Kenmore prefix) if you need the parts diagram or other information about the dryer.
Kenmore Dryers | Answered on Oct 16, 2019
Do you have the power turned on at the new location it should be a double pole 30 amp breaker in your panel
Kenmore Dryers | Answered on Oct 11, 2019
i don't know. it could be the heating a home fuse or your
dryer's heating element. open the dryer door. locate the dryer fuse or circuit breaker to see if it needs replacing or resetting. reset the breaker a few times or replace fuses with a good one. shut the dryer door and choose a new settings with high heat for a test. if OK, good. if no heat, it may be your heating element or something else. if not able to repair yourself, consider the age of your dryer and
cost of a replacement. if it runs OK and fails again in days
or weeks, your home wiring should be inspected. call for service right away.
Kenmore Dryers | Answered on Oct 02, 2019
I would check for power to the element and back to the source that switches the element on.
Kenmore Dryers | Answered on Sep 20, 2019
Kenmore 74612 Gas Dryer Logo
1 questions posted
Top Kenmore Dryers Experts
Marvin
Marvin
Ned Halaweh
Ned Halaweh
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
dryer runs ignitor
  • Dryers
