20 Most Recent
Yamaha Tilt Trim Motor, 40-50 HP Outboard Questions & Answers
What degree do you need to time a 485 yamaha engine two cycle. Want to make it turn
I have always had great results with my Yamaha and Kawasaki 2-stroke motors by setting the timing at 32' advanced. The motor will be easy to start and run much better coming out of the hole ( bottom end ). They set them up from the factory so they run rich and protect your motor. But if you want it to run like it is capable of running, you gotta bump the timing. "UPDATE">>>Im sorry i thought i was responding to ignition timing not the trim motor.
How much is a vintage low miles yamaha ex 650 worth
Two things depreciate faster than a car and they are boats and rvs. A vintage yamaha is a nice term for older yamaha. I will be worth what someone wants to pay for it. That said, if parts are still available and it runs well, no work needed, you may get $1000 to $2000 for it. But that depends on the area you are in and what other used ones are going for. All you can do is offer to sell it for some amount of money and see if anyone calls. Lower the price if no takers.
Need to know about a clicking noise motor won't turn over 97 Yamaha 75 horse boat motor
Most likely, (1) it's an old worn out battery, low charge, poor or corroded cable connections. Inspect and clean them. You may want to jumper battery with your car battery. If problem persists, (2) check starter solenoid connections and output connections. (3) As a last culprit, it could be a bad starter. And make sure your engine is not frozen. (Take spark plugs out and turn the flywheel by hand).
