20 Most Recent Kenmore 72822Gas Dryer Questions & Answers
Have a kenmore model # 110.72822101, where's the
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
4/6/2015 7:32:27 PM • Kenmore 72822Gas... • Answered on Apr 06, 2015
Hot wire my heat element on dryer
I don't see a question here, but hot wire heat element is asking to burn down your house.
5/22/2014 1:17:39 AM • Kenmore 72822Gas... • Answered on May 22, 2014
Is there a way to hot wire my dryer so it will get hot
It may be as simple as checking your lint filter. If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
5/21/2014 5:59:36 AM • Kenmore 72822Gas... • Answered on May 21, 2014
Kenmore Dryer 77832..you press the
Reach inside and turn the drum. Is it easy to turn or hard? If it is hard you might need to check the rollers or idler. If the motor bearings are dry you should try and lube it if you do not have the money for another motor. Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
8/29/2011 12:48:24 AM • Kenmore 72822Gas... • Answered on Aug 29, 2011
Our kenmore s70 dryer heats up but wont stay hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
6/12/2011 2:46:40 AM • Kenmore 72822Gas... • Answered on Jun 12, 2011
2answers
How do i change the high limit thermostat on a
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
3/21/2011 12:16:32 PM • Kenmore 72822Gas... • Answered on Mar 21, 2011
When i turn on the dryer it only stays hot for
sounds like thermostat but there is a safety feature that shut down the heat if it gets too hot, becasuse of a blocked venting within the dryer
2/26/2011 7:24:46 PM • Kenmore 72822Gas... • Answered on Feb 26, 2011
When i hold the on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
12/12/2010 8:29:30 PM • Kenmore 72822Gas... • Answered on Dec 12, 2010
Clothes not drying because of no heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
9/12/2010 10:48:08 PM • Kenmore 72822Gas... • Answered on Sep 12, 2010
Dryer runs and only blows cold air
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
4/7/2010 10:46:04 PM • Kenmore 72822Gas... • Answered on Apr 07, 2010
Dryer Not getting hot
It could be several things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or ignitor. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
4/7/2010 5:53:06 PM • Kenmore 72822Gas... • Answered on Apr 07, 2010
Dryer does not spin, it just hums
the humming noise is coming from the motor,could have a bad motor or something could be stuck in the blower wheel located under the lint filter or the belt could be jammed
11/6/2009 11:34:32 AM • Kenmore 72822Gas... • Answered on Nov 06, 2009
Dryer goes on by itself and keeps running
Check the start button for continuity. The start button should not have continuity when not pushed right? I have seen these start buttons stick. Especially these cheap little import switches. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/30/2009 9:57:48 PM • Kenmore 72822Gas... • Answered on Oct 30, 2009
Glow bar not turning on- replaced and same problem.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks
6/29/2009 5:24:49 AM • Kenmore 72822Gas... • Answered on Jun 29, 2009
Gas dryer will not heat up
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
6/24/2009 4:47:45 AM • Kenmore 72822Gas... • Answered on Jun 24, 2009
Gas dryer - Not drying
Replace the gas valve coils.
4/17/2009 5:34:47 PM • Kenmore 72822Gas... • Answered on Apr 17, 2009
Dryer heats up but drum does not turn
WISDOM If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4/10/2009 3:12:16 AM • Kenmore 72822Gas... • Answered on Apr 10, 2009
The dryer won't heat up
Check the thermo fusenormally located behind the back panel on the rear plate on the back of the drum second assumeing that the fuse is ok check the element located on the other side of the same plate that has the fuse this is assumeing that it is a standard dryer you can first test the element with your multi meter with out removeing the plate by disconnecting the wires attached to the element the easiest
being on continuaty and listen for the beep if no beep element is blown.If you need more indepth info let me know and I will see what we can do,Please remember do not undertake any repair unless the machine is off and unplugged.
1/26/2009 6:36:17 PM • Kenmore 72822Gas... • Answered on Jan 26, 2009
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered 21 hours ago
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Kenmore 72822Gas Dryer Logo
21 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
change high limit thermostat
  • Dryers
