20 Most Recent
Mitsubishi LT-46153 LCD TV Questions & Answers
Why does green light stay on when picture is shut off with cable remote from cable box
You need to "pair" your cable remote to your tv. The proceedure will vary with cable supplier. Comcast remotes come with a paper listing codes to put in. Metronet has the following: Press and hold setup until led light blinks twice. press a mode key tv dvd aux. press and hold ok key until the device turns off. Other suppliers, your on your own.
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
