20 Most Recent Magellan RoadMate 1440 Car GPS Receiver Questions & Answers
How to UNINSTALL mgnShell.exe from my GPS Magellan RoadMate 1440. The mgnShell.exe performed an illegal operation
I have the same problem, no SD card in, Jungle Ghost, the problem is not being able to get to the menu as the application error screen just hangs up on the splash screen. this also happened to me when updating via application manager.I have contacted Magellan support also and they are not [email protected] is anyone has suggestions.
8/30/2018 11:57:02 PM • Magellan... • Answered on Aug 30, 2018
0answers
How can i download philippine
When available, map updates can be purchased from the Magellan website. For the latest map update please visit our software page by Clicking Here
2010 Spring Map Update has been released. Please refer to the map's product page for unit compatibility and installation instructions. You may need to install Magellan's Content Manager on your PC in order to download the latest maps for your unit. To install the Content Manager please click here
*For specific map update installation instructions please see the installation instructions included with your map update version.
Hope helps.
4/14/2017 8:10:19 AM • Magellan... • Answered on Apr 14, 2017
Decided to upgrade my software
this is one of the perils of updating a magellan.
it sounds like the update has not taken. i suggest (if you havent already) you try the update again and if that fails, call magellan for a free replacement or repair.
Magellan will repair or replace any of their gps units rendered inoperable do to one of there updates regardless of the warranty (i assume you got this update off there site, because they will ask)
you can contact them at the number below
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
bill
10/8/2015 12:08:18 AM • Magellan... • Answered on Oct 08, 2015
0answers
Magellan roadmate 1440 fatal error
Same has happened to my gps unit too. The best bet thing is to contact Magellan and they will advise you to send the unit in for replacement with a refurbished one. or get a new one. I am still waiting for mine and as of date, nothing yet. How is it that their updates caused the fatal error? Anyone??
8/22/2014 5:07:19 PM • Magellan... • Answered on Aug 22, 2014
0answers
Magellan no voice
Be the first to answer 6/26/2014 3:08:19 AM • Magellan... • Posted on Jun 26, 2014Be the first to answer
0answers
2answers
Magellan Roadmate 1440 certainly dead
Hi onestrategy,
These are tips I have used and given others about this series Magellan units. Make sure you have external power hooked up for best results.
Magellan RoadMate models 1340, 1440, and 1470 are normally reset as follows: The reset button is located on the right side of the unit. Press a blunt object like a long-shaft ballpoint pen or a cut off toothpick into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by holding the Power button down for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on. Also, here's another procedure you really only try as a last resort, if the unit is on, but acting up with various menus and functions. Use this very carefully... While on the main Menu Bar at "System Settings", tap the left corner twice, right corner twice, left corner once, and finally, right corner once. You will see a 'Hidden' menu with a "Reset for first use". Press that option and the unit will perform a hard reset. Hopefully, you can continue all you setups from this point. Also you can download a complete manual from this link: http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf The manual won't tell you all these little tricks, so it might be a good idea to make a hard copy of these notes (in case you ever need them again...lol). I hope this helps. Please let me know how it turns out, and contact me if you need further help. Regards, Bill
8/22/2013 9:30:11 PM • Magellan... • Answered on Aug 22, 2013
Magellan roadmate 1440 froze in the first window , with the little clock at the bottom
Most of these devices have a reset button on the unit base. It looks no bigger than a pin head and is usually recessed. Turn on and take a straightened paper clip or cocktail stick, press into and keep pressed the reset button for a slow count to 15. Release and then let the unit go through its reset procedure before pressing anything else.
4/10/2012 1:26:07 PM • Magellan... • Answered on Apr 10, 2012
How do I create an account with you people
Since you were able to post this question on FixYa, you already have created a FixYa account.
3/17/2012 4:09:50 PM • Magellan... • Answered on Mar 17, 2012
My gps is complite frosen
HelloIf you cant access even its menu, and all are fully frozen out, you have to contact the authorised service center to set it to its default stage. If you can access its menu option, you can set it a factory reset option there will make the set right. It is best to contact the service center, so that they can reinstall the software to it with a latest one. OK.
2/15/2012 5:25:04 PM • Magellan... • Answered on Feb 15, 2012
Magellan RoadMate 1440 Car GPS Receiver Logo
158 questions posted
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
View Most Popular
RoadMate Magellan
  • RoadMate Magellan
Most Popular Question
any free roadmate 1440 map updates
  • GPS
