20 Most Recent Sony DSC-S930 Digital Camera Questions & Answers
Reset button?
Mostly, it's gonna be with your camera battery, try switching it for a new one, it's gonna cost like 20 bucks or so, It happened with mine too and that's why I feel your pain xD
12/10/2013 9:59:16 PM • Sony DSC-S930... • Answered on Dec 10, 2013
Reset button??
i bought the optimus camera. it was never opened. but i need a batter and cannot find one. i went to raido shack to buy one they said they no not make batteries and more for that camera. it is the siliver camera
12/10/2013 9:47:56 PM • Sony DSC-S930... • Answered on Dec 10, 2013
Format internal memory
My internal memory takes only 3 pictures. I bought an appropriate disk and all is well - and with the disk I can download to my computer.I would not rely on the internal memory if you want to take lots of pictures.
11/27/2012 8:10:49 AM • Sony DSC-S930... • Answered on Nov 27, 2012
Downloaded the driver, but still getting 'USB device not recognised'. HELP!!!!
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
6/1/2012 4:25:16 PM • Sony DSC-S930... • Answered on Jun 01, 2012
2answers
My Sony DSC-S930 camera says file error?
Get a card reader and use it to download to a folder you create on your desktop. If that doesn't get you all of your pics, take the card to a Walmart store and use their picture kiosk machines to print the pics or even make a CD of them. Once the pics are safe, you can format the card in the camera to get it erased and back to original condition.
10/28/2011 8:15:37 AM • Sony DSC-S930... • Answered on Oct 28, 2011
2answers
When i turn on my
There are two possiblities that I can think of. First is the memory card has gone bad for some reason. Can you check it with another device in your house, like a computer or printer that reads memory cards? Put the card in one of these and see if there is a problem reading the card. Does the camera take pictures OK and store them on the card OK? But when you try and erase them is this when you get the message? Is the card installed correctly? You can get a new card for very little money, especially now that christmas is coming up, these are on sale everywhere. If the card is not bad then the camera should be looked at by a repair person. Make sure the card is all the way inserted in the camera!
10/8/2011 5:14:30 AM • Sony DSC-S930... • Answered on Oct 08, 2011
When camera turn , on
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Setting Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
8/20/2011 3:08:42 PM • Sony DSC-S930... • Answered on Aug 20, 2011
2answers
Keep getting a message to turn power off and on
You have a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/1/2011 5:57:05 PM • Sony DSC-S930... • Answered on Jun 01, 2011
We are having issues uploading
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/13/2011 6:19:20 PM • Sony DSC-S930... • Answered on Apr 13, 2011
I have sony-dsc -s930<cybershoot>.at present
Try NOT connecting your camera to your computer.
4/5/2011 5:45:27 PM • Sony DSC-S930... • Answered on Apr 05, 2011
2answers
My sony dsc-s930 turns itself
Hi, 1. Remove the batteries and clean the battery contacts inside the camera with a soft cloth. Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries.
2. Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button.
3. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens.
4. Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Hope this helps. Shane
3/29/2011 1:10:36 AM • Sony DSC-S930... • Answered on Mar 29, 2011
2answers
When i try to upload
The display on your camera shows that the usb connection of your camera is active and communicating with your computer. Right after you plug-in your camera, some computers are set to open an autoplay dialog box, similar to Fig1.
mongkey_5.jpg Don't worry if this dialog box does not open. Some don't because of personal settings made earlier or the proper driver for your camera to be recognized by your computer is not installed. Install appropriate driver and software for your camera. Click this link to download and install them in your computer. Do not forget to choose your Windows version. Fig.2.
There are two ways to download your pictures from your camera.
First, through the Picture Motion Browser.
Second, through navigation of your folders and storage disks. These steps are applicable to any other cameras:
· Open "My Computer" or "Computer". It will show you all the storage disks available, similar to Fig.3.
mongkey_6.jpg · Double-click on the Removable Disk assigned for your camera. Commonly, it will show you 2 folders. One of them contains your pictures.
· Select all pictures. Ctrl+A.
· Copy all pictures. Ctrl+C.
· Create a folder in pictures folder then label it.
· Paste all pictures. Ctrl+V. Wait till all pictures are copied into the folder you created.
I hope this works for you. Goodluck!
Mongkey
"Understanding explains better..."
1/25/2011 3:44:39 AM • Sony DSC-S930... • Answered on Jan 25, 2011
I have a sony DSC-930 digital camera and everytime
have u fixed it since this post up? i am having the same problem. i placed new batteries and its still doing it. when it shuts off the lens is still out. i was think the new aa batteries were of poor quality but i doubt it that this will fix it. when i view photos it switches off, sometimes i jus need to switch on and it will automatically switch back off. arrgh
1/23/2011 7:07:24 PM • Sony DSC-S930... • Answered on Jan 23, 2011
Can i use my cyber shot as a web cam???
Many people ask if they can use their digital camera as a webcam. In the early days of digital imaging, it made sense to dual-function a camera because a webcam was a serious investment. However, webcams are now so inexpensive that manufacturers are not considering this functionality important in their digital cameras. In fact even the word 'webcam' creates the impression of bad imaging, so associating this function with a camera actually makes the camera seem 'cheap'.
So, why do so many people ask if they can do this? I believe it's caused by the 'grandfathered camera' problem. Advances in camera design have been so stunning in the last few years that it makes no sense to use an old camera when you could use a new one and get better pictures. But what do you do with the old camera? This is where people start thinking "I wonder if I can use this as a webcam?".
So, can your camera be used as a webcam? Probably not, but here's how you can tell. Make sure you've installed all the software you can find for your camera, power it up, and plug it in. Windows will tell you if it has a webcam function. If it's a webcam, then it will appear in "My Computer" as a device, right along with all the disk drives. To be sure, go to your control panel and select "Scanners and Cameras". Is your camera listed? If not... it's not a webcam.
In the unlikely event that you have a 'video in' on your computer, and that your camera has a 'video out' then you can follow the instructions on the sony site ("how to use a digital still camera as a webcam"); but most people will not have that yellow 'video in' connection.
Your camera doesn't work as a webcam? No, I thought not. Here's a different suggestion for what to do with that old camera: keep it in a different place. Seriously, keep it in the car, at work, or at the cottage. One day, something interesting will happen there, and you'll be grateful of a camera to hand!
1/21/2011 2:59:38 PM • Sony DSC-S930... • Answered on Jan 21, 2011
Turn the power off and
turn the power off and on again something maybe help
1/10/2011 4:21:11 AM • Sony DSC-S930... • Answered on Jan 10, 2011
When I review my pictures
Try to download your pictures to the computer. First make sure the camera has enough power to download the images without stopping. Connect the USB cable to the computer make sure the camera is off when you connect the mini USB end to the camera, then turn the camera on and depending on your computer operating system an icon will show on your desktop or in system preferences and an external hard drive. Once you have the pictures safely on your computer Hard Drive "eject" or click the icon to close and wait for safe to remove device )depends on system) then format the memory card always format the card or delete pictures in the camera not the computer.
12/28/2010 10:14:51 PM • Sony DSC-S930... • Answered on Dec 28, 2010
I cant install this drive
use the cd that came in the camera box and install the camera driver in your computer.
12/17/2010 3:51:34 AM • Sony DSC-S930... • Answered on Dec 17, 2010
I cant install my Sony DSC-S930 Digital Camera it
Do you have a cd for it? If yes, insert it and run the setup from the disc. If no, then you have to goto sony's website and search for your camera's driver.
12/7/2010 7:32:24 AM • Sony DSC-S930... • Answered on Dec 07, 2010
Can i use it as Webcam? If so how?
It's actually made for point and shoot purposes only. But if you badly need it as a webcam you can try these steps: 1. install the s930 software disc.
2. plug in the camera to your computer via usb.
3. After installation, restart the computer.
If you use Yahoo Messenger, go to preference , then webcam, then select your camera then press OK and test the camera. Same logic applies to other messenger apps.
Disclaimer: Better to use an actual webcam w/c is easy to setup and use
11/27/2010 3:06:22 PM • Sony DSC-S930... • Answered on Nov 27, 2010
Sony DSC-S930 Digital Camera Logo
44 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
format internal memory
  • Cameras
