20 Most Recent
Seloc Mercury Outboard Repair Manual, 1965 - 1989, 40 - 115 HP, 3 - 4 Cylinder, 2 Stroke, 1406 Questions & Answers
My boat motor has low compression @ number 1 cylinder how can I fix it
2 possibilities:
-1 Your head gasket is burned. Caution, some Mercury engines have no head gaskets. I could tell if I had your serial number.
-2 Your cylinder has seized. If it's the upper cylinder, you'll have also to check your cooling system! Look at your spark plug if you can't see some 'aluminum' deposit on it. Or, inspect the inside of that cylinder with an endoscope.
Such an old engine is mostly not worth a complete overhaul. So, in case of seizing, just hone that 1 cylinder and use a new piston with rings.
It's in any case better not to use that engine in this state.
1976 115 hp mercury outboard motor manual
fuel goes in at connector then to fuel pump then to carbs ! remove connector off fuel line and prime fuel up so you know you got fuel ! then reconnect to engine and prime up again till you see filter filling and bulb should harden , then remove a drain screw from carb bowl and prime again and see if fuel comes out of all carb drains ! if yes then start engine with or in water with kill lanyard on if ok then good ! not then check sparks on all plugs putting them against the head for earth and crank to check ! if ok then i would remove carbs and clean the jets etc ! compressions 100psi or more on all cylinders ! less means recon pistons etc !
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
What is the most expensive yacht in the world?
Off-course There are so many companies who are offering expensive yacht charter for rent in and around Europe. I suggest you to enter Kavas is the only yacht chartering company in Greece with over 25 years of experience in our industry. Kavas is offering all range from reasonable to luxury yacht services in Athens, Kos Island and Lefkas Island. For more details visit
Bareboat or Crewed Yacht Charters in Greece
10/13/2023 4:52:02 PM •
Boating
Answered
on Oct 13, 2023
