20 Most Recent
Toshiba Satellite L305D-S5934 Notebook Questions & Answers
My laptop is moving really slowly and google won't load. I have chrome Wrong computer above should be Toshiba Satellite PC
To fix this multi problem laptop i would suggest to perform complete optimization. Here are few tips:- Reinstall chrome- Remove temporary internet files- Stop unwanted services- Repair corrupt registry entries- Update the drivers that control your PCFor an instant fix use Intel Software Partner Reginout.To download and install the latest drivers use ddriver scanning tool that will search for updated drivers online. You can get driver scanning tool here:www.DriverScanner2013.net
12/5/2012 11:38:19 AM •
Toshiba...
Answered
on Dec 05, 2012
F2 and f12 keys do not function
Is this your laptop?If it is then First check your system resolution .And also check the flex cable which can effect your display if it is cut off.....And if it is desktop then check system resolution..i think it may be effect of resolution...If you need any kind of technical assistance you can contact support cell at
http://www.vtechsquad.com/
11/19/2012 10:05:22 AM •
Toshiba...
Answered
on Nov 19, 2012
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
10/26/2012 1:06:01 PM •
Toshiba...
Answered
on Oct 26, 2012
Whats the volts a battery charger should put out
Hi,please visit the URL below...The website has this
http://www.toshibadirect.com/td/b2c/adet...
"Power: 120V-240V/ 50-60Hz Frequency (Universal) input voltage,
19V x 6.3A output" or
Input : AC 100-240V - 2.5A 50/60 Hz - Output : DC 19V, 4.7A, 90W
both are for it...just one is bigger from " watt " point of view..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
6/26/2011 3:58:35 PM •
Toshiba...
Answered
on Jun 26, 2011
Haw mony this
If you're asking how much this costs it's about $619.99.
5/9/2011 4:32:07 PM •
Toshiba...
Answered
on May 09, 2011
I just bought a new tv that supports VGA
the laptop is most likely treating the tv as a monitor, there may be a setting to change it to tv on the laptop. Usually the tv can also be set up to use the vga as a tv type signal, there is probably a setting in the menu that will let you change it to computer.
3/2/2011 11:08:33 PM •
Toshiba...
Answered
on Mar 02, 2011
My toshiba dvd player has stoped working and its
Hi There!
I had the same issue happen to me before too.
I understand your frustration & how you feel.
The dvd player board has probably been damaged.
Most likely hit hard on the ground or object.
Very rare that the board isn't connected inside.
I wish I could help you any further!
Please let me know what happens!
Will be happy to assist you anytime =]
I hope I helped you & that this post is helpful to you at most!
Don't forget to rate! ;)
1/14/2011 6:35:50 PM •
Toshiba...
Answered
on Jan 14, 2011
I dont think my fan works on my laptop it keeps
Go to an office supply store and they have the cans of purified compressed air. Open the compartments and with the power off and the battery removed, spray short basts of air in all the grills and open compartments.
6/29/2010 2:42:15 AM •
Toshiba...
Answered
on Jun 29, 2010
