20 Most Recent Intel DG41RQ Motherboard CPU Bundle - Pentium Dual Core E5200 2.50GHz Retail Processor Questions & Answers
When i start my system
it sounds like the memory is at fault
10/31/2017 8:56:03 AM • Intel DG41RQ... • Answered on Oct 31, 2017
Motherboard drivers lan
9/12/2013 9:13:59 AM • Intel DG41RQ... • Answered on Sep 12, 2013
E5200 drivers
Hello the drivers can be downloaded here:https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQBut first select your windows system.And heres the ram support:http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029920.htmYour mainboard supports DDR 2 ram, up to 8 gb.Please select a quality brand, the cheap ones does not last long.Good luck
6/24/2013 11:15:19 AM • Intel DG41RQ... • Answered on Jun 24, 2013
Zenith e7500 driver
http://www.innovative-sol.com/drivermax/FREEWAREPROGRAM.LISTING ALL YOUR DRIIVERS AND MISSING DRIVERS.
5/14/2013 5:55:22 PM • Intel DG41RQ... • Answered on May 14, 2013
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
12/14/2012 1:12:39 PM • Intel DG41RQ... • Answered on Dec 14, 2012
2answers
Intel pentium dual core e 5200 2.50ghz processor
sound device
12/9/2012 2:12:26 PM • Intel DG41RQ... • Answered on Dec 09, 2012
Will the Intel DG43GT motherboard work with Intel Pentium D 950 3.4Ghz Cpu?
Here are the support CPU's. Not listed even though both are 775 socket. Might be a BIOS incompatibility http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=DG43GT . Good Luck
8/29/2012 8:07:06 PM • Intel DG41RQ... • Answered on Aug 29, 2012
I have a intel DG41RQ
I have a problem, when i connect usb mouse, keyboard, printer and scanner. USB work fine, but i connect my Q Mobile then driver not work properly... when i try it to another system Q mobile work fine.Abdul Ahad AmmarHow to Lose Cheeks Fat
4/30/2012 10:49:12 AM • Intel DG41RQ... • Answered on Apr 30, 2012
Please send me the address
Hi, Arihant Systems.... m.i road,304,s.s tower new colony ,m.i road ,Jaipur Rajasthan 302001.India
+91 141 510 1916
8/20/2011 7:05:55 AM • Intel DG41RQ... • Answered on Aug 20, 2011
Lots of drivers are either
if you are having trouble with your drivers here is a general look at the drivers and how to update them if your computer came with a motherboard disc the drivers could be on it click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver hope this helps
6/3/2011 6:37:50 PM • Intel DG41RQ... • Answered on Jun 03, 2011
I want intel DG41RQI motherboard drivers CD, how?
You can download this driver cd from Many Website. If it is in Image File It Will Be Better. First Download the Image File. And Save It. If you try to open that file. It will Open with Nero Software. Automatically Nero Dialog Box Will Appear. Then Change into the "Current Recorder" Box. Just Select
Drive H:TSSTCrop CDDVDW SH-S223C (DVD) or I:HL-DT-ST DVDRAM CGH22NS50 (DVD). Then Burn. automatically it will change Program File Or Setup File. Then U Can Use That Dvd To As Driver Cd. Ok. Just try It.
5/9/2011 10:13:59 AM • Intel DG41RQ... • Answered on May 09, 2011
Hi. Motherboard DG41RG, sound included.
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer make sure you have an earth ******** before touching any parts inside your computer hope this helps
4/25/2011 10:11:16 PM • Intel DG41RQ... • Answered on Apr 25, 2011
My Intel Board DG41RQ beeps
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM is securely seated test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
4/2/2011 8:11:59 PM • Intel DG41RQ... • Answered on Apr 02, 2011
4answers
Intel dg41rqi original ddr2 motherboard
as long as it is a lga 775 socket chip it will workbut that chip will work no problem
3/11/2011 10:42:22 AM • Intel DG41RQ... • Answered on Mar 11, 2011
2answers
I need Intel Dg31Rq vedio
Here is the download page for the drivers for your motherboard. Choose your Operating system and download the Video drivers and chipset drivers. Good luck!
3/5/2011 2:22:06 PM • Intel DG41RQ... • Answered on Mar 05, 2011
4answers
How can i get get
Greetings - There is no Bluetooth built into the motherboard, so I can't imagine what drivers you are referring to? Perhaps you are referring to a Bluetooth device you want to use with the board? If so you would have to get the drivers from the device manufacturer.
The full spec sheet for the board is located here:
http://www.intel.com/Assets/PDF/prodbrief/DG41RQ-prodbrief.pdf
Regards, Mikeywaf
3/3/2011 9:45:20 AM • Intel DG41RQ... • Answered on Mar 03, 2011
I have no drivers, i
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
2/28/2011 5:50:36 AM • Intel DG41RQ... • Answered on Feb 28, 2011
Intel DG41RQ Motherboard CPU Bundle -  Pentium Dual Core E5200 2.50GHz Retail Processor  Logo
Popular Tags
53 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
zenith e7500 driver
  • Computers & Internet
