The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Although on some motherboards the Cmos battery is soldered in
if this failsclick start type cmd press enter
At command prompt type debug you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)A <ENTER>MOV AX,0 <ENTER>MOV AX,CX <ENTER>OUT 70,AL <ENTER>MOV AX,0 <ENTER>OUT 71,AL <ENTER>INC CX <ENTER>CMP CX,100 <ENTER>JB 103 <ENTER>INT 20 <ENTER><ENTER> just hit enter on this lineG <ENTER>Q <ENTER> Basic BIOS password crack - works 9.9 times out of ten hope it helps
27 questions posted
606 Questions
252 Questions
223 Questions
195 Questions
195 Questions
