20 Most Recent
Kenmore 84072 Electric Dryer Questions & Answers
Runs for little while then
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
I have a kenmore dry
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
My dryer doesnt heat. I
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101;'
Dryer has power, buttons on front beep when
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
The tube spins, but there
gas no heat tip....
check out this
heatman101
Kenmore electric dryer--model 41784092500. When I
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
You don't
have to accept or reject
and rate this post
to add information
or post comments and follow-up questions. Accepting a solution does not
stop you from communicating
with an expert. You may continue communicating with the expert as
long as you need assistance regarding the issue stated herein.
Time to change the dryer or is it worth fixing?
this could be something as simple as a loose or stretched out belt to a jammed pressure roller to a bad motor. could also be the drum is not mounted right due to worn out or missing felt pads and is causing a binding at the front or rear of the unit.
Heating element is going out it work about ten
It may be your heating elements, but I would check your circuit breaker to make sure its putting out 110V on each phase as the heating elements are the only part in your dryer that use 220V, so if the circuit breaker is not outputing enough voltage that could be your problem (it's also a less labor intensive fix). NOTE: IF YOU ARE GOING TO REPLACE YOUR CIRCUIT BREAKER TURN OFF THE MAIN BREAKER TO HOUSE TO POWER DOWN THE BUSS BAR THAT THE BREAKER IS PLUGGED INTO.
