20 Most Recent Biostar G31D-M7 Motherboard Questions & Answers
JAUDIOF1: Front Panel Audio Header
the manual is here the pinout is told and there are 10,000 DIY case made and they are wired unique for front panel audio jacks we must wire them custom to do that. end to end. (find a tech as them to do that job) have manuals for both in hand, bios star and the new diy case manual. or the job is 10x harder. done many but , gee 10,000 cases no the same. there is no ATX front panel spec. sorry, same with usb front. same with power button. the mobo is DIY, means , knowing how to do DIY only works.
6/6/2022 1:30:26 PM • Biostar G31D-M7... • Answered on Jun 06, 2022
Biostar mb power setting
Standby is like the monitor powers off. You want to select the option for spindown disk when possible, and select hibernate. That is probably what you are looking for. Also check in the BIOS for additional power settings.
1/22/2018 8:28:35 PM • Biostar G31D-M7... • Answered on Jan 22, 2018
How do i fix my usb slow data transfer speed
Make sure that JUSBV1: Power Source Header for USB Ports Pin 1-2 Close: +5V for USB ports at JUSB2/JRJ45USB1 If the jumper is on 2-3 the standyby section may not be providing enough current, thus causing the problem. With some USB devices this problem of high current demand is so severe that a USB3 add in card has to be put into the system to meet the current demand. The USB3 cards have a receptacle on the rear of the card where one of the power supply Molex cables is plugged in. This ensures adequate current and voltage. USB3 can provide 1.5 Amp, USB2 only 1 Amp.
7/22/2015 8:23:07 PM • Biostar G31D-M7... • Answered on Jul 22, 2015
Warranty check
go to bio star support there they can help you
4/23/2014 6:00:41 AM • Biostar G31D-M7... • Answered on Apr 23, 2014
Please reset your cmos overcloking problem no
Power down the motherboard, and remove the power cable going to it. Then remove the CMOS backup battery... its usually a little coin-sized battery in a holder that has some kind of latch holding it in. There may be a jumper near it that says "Reset CMOS" and you can briefly put the jumper that is there across those two pins. Then in a few seconds put it back where it was. Or, leave the battery out for about 15 minutes and that should do it. Then put it back in and restart the computer. Should be OK now.
12/17/2013 1:00:35 AM • Biostar G31D-M7... • Answered on Dec 17, 2013
0answers
H61mlv2
Be the first to answer 12/7/2013 9:33:42 AM • Biostar G31D-M7... • Posted on Dec 07, 2013Be the first to answer
I want biostar g31d-m7 Warranty Check
I wouldn't hold your breath. It is a Socket 775 mobo and so has not been in manufacture for at least a year (since 2009 to be precise). Incidentally, Biostar is the company you should be checking with.
11/14/2013 11:08:09 AM • Biostar G31D-M7... • Answered on Nov 14, 2013
Power problem
Pay your bills.
8/20/2013 5:50:21 PM • Biostar G31D-M7... • Answered on Aug 20, 2013
Warrenty checkup
biostars g31m sn H112807562
7/17/2013 10:43:29 AM • Biostar G31D-M7... • Answered on Jul 17, 2013
Hey buddies i got my system 2 years back n i had problem with a blue screen error....!! what should i do..! i've replaced my hard disk and my RAM ...!!! although it is showing the same error..!! p
bluescreen can be caused by a number of things
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your systemif you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
a bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to failmake sure all leads have a dust free secure connections
a bad driver loose or faulty lead or not having enough ram
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over hope it helps
7/22/2012 9:15:02 PM • Biostar G31D-M7... • Answered on Jul 22, 2012
My usb drive is very
You need a small file from BIOSTAR that adds USB 2.o support. Go here :http://exehub.com/biostar-g31d-m7-motherboard-drivers-specs/ and go to the bottom file,download it and install it and you'll be good to go :) cheers.
1/3/2012 3:00:22 AM • Biostar G31D-M7... • Answered on Jan 03, 2012
2answers
How to go to BIOS
Press Del when the pc starts.
1/3/2012 2:52:23 AM • Biostar G31D-M7... • Answered on Jan 03, 2012
2answers
My usb is set of 1.1 & hight speed 2.0usb not
upgrade the bios...
it's the way...
1/2/2012 6:18:15 PM • Biostar G31D-M7... • Answered on Jan 02, 2012
I've been asigned with a
if you don't have a 'power button' just quickly sort the 1 and 2 pins on the board that say "power button" in the lower corner and it will turn on
1/2/2012 3:43:30 AM • Biostar G31D-M7... • Answered on Jan 02, 2012
Are there sound settings on mother board
Yes, if you enter setup(by hitting DEL)on startup you can enable or disable sound in the "devices"section. if it's enabled and not working try reloading the driver http://206.108.48.60/app/en/mb/introduction.php?S_ID=386&tab=3 from here.also make sure your speakers are plugged in properly and try another pair.
1/2/2012 3:42:02 AM • Biostar G31D-M7... • Answered on Jan 02, 2012
My pc motherboard is G31D-M7.
Go here and if it's ver.7xx or 8xx use these. If it's 6xx you can look from the top of the bar http://206.108.48.60/app/en/mb/introduction.php?S_ID=386&tab=3
1/2/2012 3:40:07 AM • Biostar G31D-M7... • Answered on Jan 02, 2012
I lost my motherboard cd
Go here and all your drivers and files and manuals are listed http://206.108.48.60/app/en/mb/introduction.php?S_ID=386&tab=3
1/2/2012 3:38:44 AM • Biostar G31D-M7... • Answered on Jan 02, 2012
Biostar G31D-M7 Motherboard Logo
41 questions posted
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Biostar Computers & Internet
Most Popular Question
warrenty checkup
  • Computers & Internet
