20 Most Recent
HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001 Questions & Answers
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
Charging diagram for 431426-001
if your power supply is good then your board will have power if not then the board is bad. there is no charging diagram make sure that all power plugs are on board are in
Hp say hard disk failed 301
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
My dv6000 will not come on, the lights come on fro
You are in for a rough fix. See the HP forum and follow the directions on this web posting. Get a PC geek to help.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1269377543004+28353475&threadId=1147659
Search for the date given below:
Nov 22, 2009 16:10:23 GMT
Unassigned
HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems
described in the previous posts are Graphics Related..
Faulty Nvidia
Chip..Both Intel And AMD Based Motherboards..Though More Common on the
AMD..
The symptoms of the Laptop Powering on and Shutting Off
Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip
Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant
Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To
Fix this issue, You will need to Reflow The Graphics Chip.
I
will Explain In Full Detail As To The Correct Method Below....
HP
DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First
Step Is Complete Disassembly Of All Parts And Components..
Remove
RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Hp dv6600 manual
Hi thereI think that this link might be of use to youAll the bestkolbrunhttp://www.retrevo.com/support/HP-DV6600-Laptops-manual/id/19615dj380/t/2/
Black screen after BIOs startup screen.
If you cant get to the BIOS or SET-UP screen (and your sure you have power) then you have to have it checked with a P.O.S.T .card (you can find them on ebay for about $20
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
