20 Most Recent Vizio VA220E LCD TV Questions & Answers
The circuits in my tv were destroyed by lightening. If I get the parts, is it something I can fix?
Your TV is 7 years old. Fixing various circuit boards will not guarantee that your tv will work, or if it does, how long it will work. You are better off buying a replacement. If you don't have the money for a new one, look for a factory refurbished model.
3/10/2015 3:44:18 AM • Vizio VA220E LCD... • Answered on Mar 10, 2015
0answers
Vizo tv comes on with white screen then shuts off
screen should be black with a dim back light than go to video you may have a short in the panel
2/2/2013 12:21:23 AM • Vizio VA220E LCD... • Answered on Feb 02, 2013
Is Visio Model VA220E remote a version 1 or version 2?
Version 1 should be the original remote.Version 2 is a newer style of remote.Part number of your remote that is needed is 098TRABD1NEVZU I’m happy to help further over the phone at https://www.6ya.com/expert/zelio_00a80ed57645ccbf
2/19/2012 9:58:50 PM • Vizio VA220E LCD... • Answered on Feb 19, 2012
No signal is the only thing that will come on my
What is the signal source? How do you have the TV connected to the source?
For most video equipment (dvd players and other set top boxes), connect the TV to the device with everything turned off. Turn on the TV then switch to the appropriate input. Finally turn on the source device.
Check the cables to make sure that they are fully seated. Try using different cables (to rule out damaged cables).
If your source is OTA antenna, check that the antenna hasn't been rotated. (This assumes it has worked in the past.) Check your wiring for any damage. If you have an amplifier or switch in use, remove it and check if the signal comes through. (You can use a coax coupler to connect the two wires directly). If the signal is fine, replace the amplifier. If you were using a switch, either replace it with a direct replacement or with an amplified switch (in case the signal was reduced beyond the level that the tuner can receive). Also check if the fuse has been damaged, if you have a surge protection/grounding system on the antenna system. Replace the fuse if needed (this can also be the issue for satellite and some cable installs).
If your source is a computer, try a different video cable. Turn off everything before connecting the TV to the computer and turn on the TV first when ready to restart. Make sure that the video port that you are using is active. (Desktops often have on-board video and separate video cards. Only one set of ports is live.) Depending on the computer, you may need access the BIOS with the computer connected to a different monitor to change the active port. (Press Esc, F1, F2 or F10 depending on the machine immediately after turning on the computer. Sometimes I miss the timing and have to shut down the computer a second time and repeatedly hit the key to access the BIOS.) Make sure that the computer is sending a resolution of 1360x768 at 60 Hz.
If you are connecting a computer to the TV with an HDMI cable, try using the VGA (RGB) port instead. The computer's signal is not the same as that of other video set top boxes. This TV does not support a computer on HDMI.
For a laptop, you also may need to enable the external video port. Then set the OS to use the external port. (On my HP laptop with Windows 7, I can do this by right-clicking on the Display and choosing Graphics Properties. Then I can set the monitors to Dual, Extended (mode) and Laptop monitor or External Monitor (display). Then click Apply followed by OK (in a second window) to accept the changes. For other laptops, you probably have a shortcut or can do it in the OS.
If the problem occurs on all sources, the input board may be damaged on the TV. (A power surge (lightning strike) could cause the damage.) If the TV is under warranty, you should contact Vizio.
Since the inputs are directly soldered to the main board on this TV, unless you are skilled at soldering, you would need to replace the entire board. Disassemble the TV and check the current board before replacing. There are several main boards available for the TV. Shopjimmy.com lists the VA220E parts as out of stock. Partstore.com has some of the boards in limited numbers: http://www.partstore.com/Model/Vizio/Vizio/VA220E.aspx .
I hope this helps.
8/5/2011 8:55:13 PM • Vizio VA220E LCD... • Answered on Aug 05, 2011
Vizeo 50 in lcd tv terns on screen gose whit and
Make sure screen is not broken, and if turns off then check power supply and see if bulging capacitors are in PS and replace.
4/29/2011 4:43:52 AM • Vizio VA220E LCD... • Answered on Apr 29, 2011
I hooked up my vizio 22" tv up to my laptop
Check the tuner i/o board connector there might be a loose connection from the soccket.
I/O board means input output board, this is where the antenna and audio video input are pack in.It is just inserted at the socket..check whethere the connectors are lock properly
2/6/2011 11:03:39 PM • Vizio VA220E LCD... • Answered on Feb 06, 2011
Screen wont stay on
no pware
1/30/2011 6:18:57 PM • Vizio VA220E LCD... • Answered on Jan 30, 2011
Picture has constant "noise" and twitching, like a
LCD TV's have an internal screen which is 2 plates with a slight space between them.There is a part which provides electrical signals with slight variations to the first screen to produce an image to the second screen.It could be either,part the screen or the electrical emitter.I have tried many times to find parts and diagrams but the makers will not allow consumers to look at them.It will need to be looked at by a repair center.I would need to see and hear it to determine which one too.Also,repair centers have a minimum markup on parts of 20%.See if they can estimate it free or fairly cheap,then I would weigh the options between repairing/replacing it.
Good luck! Greg
8/8/2010 6:53:15 PM • Vizio VA220E LCD... • Answered on Aug 08, 2010
Red line running from the top to bottom of the screen
there is a lcd panel problum means not removable only the solution is to chang the lcd panel
1/26/2010 6:45:56 AM • Vizio VA220E LCD... • Answered on Jan 26, 2010
6answers
My new digital tv will not record on the vcr.
the Normal 21 pin scart is an input and an output device, although most applications only need them to be used in one direction.
most TV's with a built in digital facility will have the output from the scart socket activated, and a full scart lead connected from the TV to the VCR will allow the TV to send to the VCR as well as allowing the TV to receive from the VCR.
Unless you have a very new and rare free-view tuner built into your VCR you can only record free-view by connecting a eurosocket (SCART) from your TV back into your VCR. This will allow you to record the channel that your TV is set too. It will not let you watch another programme or switch off the TV while you record a programme on your VCR. (Similar to the SKY setup for vcr/tv) The only way you can record free-view directly without compromising what you want to watch on your TV is to purchase a "Free-view set top box" dedicated to your VCR and use a separate Aeriel to connect to the TV and VCR. Of course, you will still not be able to do full timer recordings as the VCR cannot change the settings of the "Free-view set top box".
to get more detailed help click this link directly
http://www.ezdigitaltv.com/VCRs_and_Converter_Boxes.html
this will help.please do rate the solution if helped.thank you for using fixya.keep updated.
9/26/2009 2:46:19 AM • Vizio VA220E LCD... • Answered on Sep 26, 2009
Vizio VA220E LCD TV Logo
29 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VA Vizio
  • VA Vizio
Most Popular Question
hooked up vizio 22 tv up laptop
  • Televison & Video
