20 Most Recent Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV Questions & Answers
Why don't you use the original one? Universal remotes provide just basic function and not full range.
Insignia... | Answered on Jan 22, 2018
You have to use a digital adapter box for your TV. The government was subsidizing these boxes to citizens who did not have some sort of cable service. You can pick one up from the store for about $40. Connect your antennae to this box and then this box to your tv. Antennae--->box--->TV. The box will adapt the local stations in your area that are now being broadcast in digital form to your TV. Hope this helps.
Insignia... | Answered on Dec 03, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Insignia... | Answered on Dec 29, 2015
most manafactors codes are 1234 or 0000 or 5555 or 8888 you might have to put extra didget on EG 12345 -00000 - 55555 -88888 but if you changed it sorry dont know
Insignia... | Answered on Oct 06, 2015
Look on the back of the set for the AUDIO OUT PUTS!!
Insignia... | Answered on Feb 18, 2015
Unit searches for all available channels
Insignia... | Answered on Feb 13, 2015
Under support downloads, download manual.
You will find it under captions not subtitles.
Insignia 32 inch Class 720p 60Hz LCD HDTV
Insignia... | Answered on Nov 10, 2014
Firmware corrupted. Do a firmware update. Contact any experienced service technician, of the authorized service centre to Insignia. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Insignia... | Answered on Mar 28, 2014
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Insignia... | Answered on Jan 03, 2014
THE MAIN BOARD, usually is a 3vdc-3.3vdc signal to turn on the power supply
Insignia... | Answered on Feb 03, 2013
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Press the CCD button on the remote control. Advanced settings are found in the Menu under Settings.
Insignia... | Answered on Dec 29, 2012
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
Insignia... | Answered on Oct 05, 2012
that's lcd tv . problem maybe in the power supply or main board. that need technician to troubleshoot to decide which one bad or botb of them bad. hope this could help.
Insignia... | Answered on Sep 04, 2012
It is OK. This is not a fault. Heat will be generated when an LCD TV works. This is common for all brands. It is not a fault.
Insignia... | Answered on Aug 12, 2012
For more details Type in this site name < Electro-help> (DO NOT copy and paste the site name from here. Doing so may lead you to wrong place) to search box of your search engine [not in the address bar of your browser], and press "Enter".
It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
You can locate this site, either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
Insignia... | Answered on Jun 08, 2012
Blowed Fuse on the T-Con Board or Bad T-Con Board.
Shopjimmy.com
Encompass Parts 1-800-638-3328
Insignia... | Answered on Aug 12, 2011
Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV Logo
Popular Tags
68 questions posted
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
turn off subtitles
  • Televison & Video
