20 Most Recent
LG 55LH40 55 in. LCD HDTV Questions & Answers
My lg tv turns off right as i turn it on. The standby light comes back on. If it sits in the sun for a while it turns on fine.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
JUST MOVED, JOSTLED TV, WILL NOT POWER, NO LIGHT ON FRONT EVEN
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Why won't it turn on?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My LG TV turns off by itself. Is it worth repairing?
it depends on how old the set is, and if you can find some one who will work on it, most problems with a LCD tv, is that one of the boards goes bad, there is a main board, and a driver for stero, and channel functions, if you can find some one, let them give you an estimate for how much it would cost, no harm in letting them look at it, but beware , parts are not cheap, so cost for new set, compaired to repair, equals what you should do
