20 Most Recent
LG 32LH20 32 in. LCD HDTV Questions & Answers
Have an lg 50pc56 that
Chances are its capacitors in the power board, once they warm up they start filtering again, common issue
Remote code to program LG 32LH20 with Comcast
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Tv or cable remote don't work on tv
Have the remote or remotes tested to be sure they are ok---failing that every set has a remote receiver inside that receives the infrared signal the remote sent---suspect number one is the remote receiver in your set.
