20 Most Recent
Samsung LE37B550A5 37 in. HD-Ready LCD TV Questions & Answers
How do I fix the picture has no blues in it ????
is this on ALL inputs?, check all input cables, at both source & TV. If you are using component input, be sure to check all cable connections both at TV & source. Check ALL cables.
1/31/2015 7:11:53 PM •
Samsung...
Answered
on Jan 31, 2015
I have a Samsung HDTV (LN-T5271F) approx 4 yrs
Do these bands appear even when no input is connected to the tv? It will help us isolate whether its an LCD controller problem or a problem with the video processing circuits
2/22/2011 2:30:59 AM •
Samsung...
Answered
on Feb 22, 2011
Add subtitles samsung
Must tries mutilple channels,pushes the remote button CC 1,2,3 on every channels.Sometime channels don't have captioning.
2/24/2010 3:03:24 AM •
Samsung...
Answered
on Feb 24, 2010
Have no sound for TV, everything else is fine
First check to see if you get it on all inputs (DVD, Cable, etc.). If you get no sound on all inputs, then do a hard reset by unplugging the TV from the wall overnight and plugging it back in and test again. If this does not work, then the main board needs to be replaced.
If you do not get it on all inputs, most likely it is just a loose connection. Check the connections going out of the source and into the TV for something that might have come loose. If everything is okay, test the bad input with something that you know has some on a different input on the TV. If this still does not work, replace the main board or simply do not use the bad input.
11/9/2009 9:45:12 PM •
Samsung...
Answered
on Nov 09, 2009
My samsun lcd vont turn on
Sounds like the powerboard to your tv went out. It can be replaced/repaired. Call your manufacturer for technical support.
8/4/2009 3:26:15 PM •
Samsung...
Answered
on Aug 04, 2009
I have sound but no picture??
vague discription , but can help here, is the backlight lit?
if not
shine flashlight on screen and see if any picture is actually there,m if there is a picture there with no backlight, could be a power issue or bad panel (screen).
if no picture but has backlight, may be Tcon board or signal board
I’m happy to help further over the phone at
https://www.6ya.com/expert/eric_ab7c09ec01841771
8/1/2009 4:02:31 PM •
Samsung...
Answered
on Aug 01, 2009
