20 Most Recent Samsung LN22B460 22 in. HDTV LCD TV Questions & Answers
0answers
My samsung ln46b610a5fxza picture started to have magenta and green and red vertical lines appear on the screen and now they won't go away
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
1/16/2018 12:19:22 AM • Samsung LN... • Answered on Jan 16, 2018
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
11/18/2016 3:00:54 AM • Samsung LN... • Answered on Nov 18, 2016
How do I troubleshoot my Samsung TV? I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
3/17/2016 10:45:02 PM • Samsung LN... • Answered on Mar 17, 2016
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
1/18/2016 3:39:48 AM • Samsung LN... • Answered on Jan 18, 2016
0answers
How do you stop flicking on model# LN40C500F3F
flicking or shutting down,i have the same tv,mine shuts down,it needs power supply,yours needs the control board,get one on ebay
5/11/2015 11:44:46 PM • Samsung LN... • Answered on May 11, 2015
Increase brightness in samsung tv
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/15/2015 9:37:35 AM • Samsung LN... • Answered on Mar 15, 2015
How to remove table stand from model LN40D630
Page 64 of the user manual explains this procedure. Go to Global Download Center and under Manuals, click See More + and then click on Download PDF.
3/3/2015 4:17:08 AM • Samsung LN... • Answered on Mar 03, 2015
Why dont i have a picture?
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps jim
3/1/2015 10:31:59 PM • Samsung LN... • Answered on Mar 01, 2015
How do I fix samsung LCD tv that will not turn on. Standby light keeps flashing but will not turn on
You can also replace the bad capacitors on the power supply board.
1/27/2015 1:03:54 AM • Samsung LN... • Answered on Jan 27, 2015
Half of me samsung lcd TV screen is shadowed with light streak going across top of screen
Sounds like the LCD Panel, if under warranty contact Samsung warranty for service. If out of warranty, watch it until you tire of it then replace the unit as the cost of a new panel is more than a new unit.
1/3/2015 4:40:39 AM • Samsung LN... • Answered on Jan 03, 2015
Too bright/high contrast, unable to adjust. Tried to adjust from MODE: DYNAMIC, STANDARD, MOVIE=NOTHING, Tried-Background, Contrast, Brightness, Color, Tint, Gamma, Picture Factory Reset=nothing.
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/ .In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
9/30/2014 7:51:30 AM • Samsung LN... • Answered on Sep 30, 2014
My samsung was hit by lighting.. the red light blinks a few times when i plug it in. and when i press power it blinks once. but will not turn on. i checked the two fuses inside and replaced them but i
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
8/24/2014 5:08:18 AM • Samsung LN... • Answered on Aug 24, 2014
Samsung TV won't turn on after lightening storm. Surge protector "sparked once, but all the other things plugged in are operating.
Contact your insurance company and make a claim. Lightning damage to electronics like that is hard to repair.
8/7/2014 11:34:41 PM • Samsung LN... • Answered on Aug 07, 2014
Samsung LN22B460 22 in. HDTV LCD TV Logo
Popular Tags
6 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
continuous crackling from tv speakers
  • Televison & Video
