20 Most Recent
LG V-280 DVD/VCR KOMBI DVD Player / VCR Combo Questions & Answers
Codes for lg
Try codes for NEC or teac as well. They are same company.
What can I do to watch DVD-s purchased in the US?
Hi,this is a very complicated isssue..Not All DVDs Play In All DVD Players
Nothing has impacted the home entertainment world quite like DVD.
Players and movies have been flying off the shelves worldwide as prices
keep falling and consumers keep buying. With superior picture and audio
performance DVD has spurred growth in home theater exponentially in
recent years. However, along with DVD's worldwide success,
comes its dirty little secret: region coding (also referred to as region
lock). ...........see link.....
Please visit the URL below for more details..
DVD Region Codes - What You Need To Know
http://hometheater.about.com/cs/dvdlaserdisc/a/aaregioncodesa.htm
Please Note: Some DVD players have an internal switch setting that allows you to choose
the country code. Others have this option hard coded. You may find a lot of advice in
newsgroups as to how to by pass this feature. Just be aware that this will always nullify
your warrantee. I don't track hacks or modifications. You may want to try a site
that specializes in these things such as DVD
Region Hacks. Again, please be warned, you can ruin your player if your
apply any unauthorized modification to your DVD player. You can try contacting
the manufacturer they often will help.-----------
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
