20 Most Recent
Kenmore 75022 / 75024 / 75029 Gas Kitchen Range Questions & Answers
I have a kenore stove
yes is it entirely possible to do that..without power the oven will not work however...good luck i was hit with hurricane irene yesterday and it was a bad one but its the cost of living on the eastern shoreline (virginia)
Oven will not ignite
On your oven have you been able to look and see the if the igniter in the oven glows yet their is no flame? the leading cause of a gas oven not heating by far is a weak or cracked igniter. If you have multimeter you could check for 120 volts ac at the 2 wires the igniter plugs into,if their is 120 volts ac present at the igniter,its going to be the problem. If 120vac not present at valve when oven set,the oven gas valve then the control are they cause..firstly check the gas valve for continuty if 120vac not at igniter, if has contunuty and 120vac not at igniter,then the control will be the problem.But first check igniter its bad 100 times for every valve or control.
Gene..OldTech2332
How do you turn off the self cleaning feature on
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
I have a kenmore gas range model # 665.75775 the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Kenmore 9114554590 will not bake or broil
The clock/display panel is faulty. There are a few relays on the display that have to work. If the clock is just flashing once with each keypress the the relays are not functioning. The clock/diplay will need to be replaced
Kenmore gas range
hi
Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Control panel & Oven doesn't work
APril b
Most likely the problem with your range is shorted pads on the key pad. It is not repairable and the key pad has to be replaced. If you would like to do it yourself, I need the complete model number starting with a three digits prefix(the name plate is located on the frame behind the storage drawer) and the color of your range. Then I'll be able to help you to find the best deal on the part and provide you with the step by step instructions to replace it.
Gendos...post back
