20 Most Recent
Digi Channel Master/tal to Analog Converter/CM-7000 Questions & Answers
Channel master cm 7000 capacitors replacement
Although replacing every aluminum electrolytic in sight is likely to bring a CM-7000 back to life, in my experience the only capacitors that have failed, in four different units, have been
E5, E6 on main board -- one unit
C12 on power supply -- three units
My Channel Master CM-7000 D2A TV Converter box is
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.On the power supply I would replace at a minimum:C14 - 4.7ufd 50v UPW1H4R7MDDC4 - 1ufd 50v UPW1H010MDDC8 - 100ufd 25v UHE1E101MEDC10 - 470ufd 16v UHE1C471MPDC12 - 1000ufd 10v UHE1A102MPDThere are 4 others in the supply that were not grossly bad.C1 - 22ufd 400v EEU-EE2G220C7 - 220ufd 25v UHE1E221MPDC11 - Same as C10C13 - Same as C10Logic board:E5 - 33uf 35v EEU-FM1A471E6 - Same as E5Part Numbers of replacement caps are Nichicon or Panasonic.Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.Contact me if this is beyond your skills for possible repair.
My box will only show
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
Red light won't turn to green
I have channel Master 700
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
I lost all the tv channels on channel master
First look at the indicator lamp on the front left side. If it is:off - check the power cord is plugged into a working outlet.Amber - the unit is in standby, press the on button (left most), it should turn greenGreen - the unit is in operate mode, check the antenna and cable connection.Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
I have a Channel Master
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
