20 Most Recent
Amana LGA10 Dryer Questions & Answers
The flame won't light everytime I turn the dryer
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this
electric no heat tip...
heatman101
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Dryer runs but no heat
if the glow bar is lighting the next thing will be the gas valve there are two coils on top of the gas valve that have wires going to them replace both coils "they come as a kit"
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
DOES NOT HEAT. bUT DRYER TURNS
looking at the model # i believe this is a gas dryer? the machine is likely not igniting therefore not heating. you need to look at the glow coil to see what color it is. if it is orange in color you need to replace it, because it has to glow white hot in order for it to ignite the gas from the gas valve.
Amana dryer runs for 5 seconds. chimes with TS error code. I replaced thermistor and cleared code. still same issues. Help.
Check your lint screen and vent for restrictions or clogs. Then check the resistance for the thermistor at the control board. You need to confirm that the wiring and replacement thermistor are undamaged. Look for the white connector and test across pin 2 (blue) and pin 6 (red). If the resistance is in range, then the control board is faulty. Replace the control board.
I hope this helps. Since you already replaced the thermistor, I assume you know where to find the parts list for your Amana dryer.
7/31/2022 9:30:18 PM •
Amana Dryers
Answered
on Jul 31, 2022
