20 Most Recent
Giorgio Armani Armani Bracelet watch #AR5330 Watch for Men Questions & Answers
My Emporio Armani 5330 has
Simply advance hands 12 hours forwards (clockwise). Just pull out crown to the time setting position and turn the watch hands forwards if the date is changing before midnight. If the date is changing after midnight - turn the hands 12 hours backwards. Don't do this when the actual time is between 10pm - 2am.
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
