20 Most Recent Olympia Standard 300 Typewriter Questions & Answers
You probably have the right margin set there.
When you get to that point press but don't hold the mar rel key space to the location for the right margin press the R margin key.
DickyO
Olympia Standard... | Answered on Mar 24, 2015
Goto nadist.com click on current models you will find a Nakajima that is the same as tours.
DickyO
Olympia Standard... | Answered on Mar 08, 2015
Go to www.nadist.com and download the manual for the Nakajima AE-800....ITS THE SAME MACHINE.
Olympia Standard... | Answered on Feb 19, 2015
If pressing the return key doesn't do it you have a keyboard problem.
DickyO
Olympia Standard... | Answered on May 21, 2014
Check the pitch slide switch it should be in 10 or 12 not PS. Slide it up & down a few times they do get dirty.
DickyO
Olympia Standard... | Answered on Jan 23, 2013
You are in the over strike ribbon mode. The code and period, comma or slash (I can never remember which) will get you out of the mode.
DickyO
Olympia Standard... | Answered on Sep 12, 2012
The 300 takes all nakajima, swintec or compatable Printwheel the typestyle is up to you.
DickyO
Olympia Standard... | Answered on Sep 12, 2011
If the keyboard does not work "at all"..but you do have power then you may have lost the Program e-prom on the Main pcb or the Main pcb itself. This would have to go to a shop for repair.
Olympia Standard... | Answered on May 31, 2011
I'm guessing that you want to move the R. margin. Go to the margin press but don't hold the mar rel key space or backspace to desired location, press R. mar key.
DickyO
Olympia Standard... | Answered on May 19, 2011
During correction the lift-off tape is raised. Please check that it goes down and does not interfere with the printing ribbon.
Removing and reinstalling both is probably the best way.
Olympia Standard... | Answered on Apr 01, 2011
It takes a General Ribbon T325 or a Nakajima XC001 ribbon. Hope this helps.
DickyO
Olympia Standard... | Answered on Jan 28, 2011
This is tickyOhe same as a nakajima AE710. Go to NADIST.COM, click on current models you will find a manual there.
DickyO
Olympia Standard... | Answered on Jan 21, 2011
Press the repeat and the last letter will print.
DickyO
Olympia Standard... | Answered on Jan 12, 2011
I belive That this T/W dose not have an addressable memory. Go toNADIDT.COM click on current models the ae710 is the same as your T/W.
DickyO
Type a wrong letter, press correction key (X WITH AN ARROW POINTING NTO THE LEFT) should remove Mistake. If this dosen't work you may have very old supplies or a non correctable ribbon.
DickyO
Olympia Standard... | Answered on Dec 14, 2010
Olympia Standard 300 Typewriter Logo
35 questions posted
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Olympia Office Equipment & Supplies
Most Popular Question
after pressing correction key could not
  • Office Equipment & Supplies
