20 Most Recent
Texas Instruments TI-30XA Calculator Questions & Answers
How to convert mL to fl oz ?
One millileter is about 0.033814 fluid ounces, so to convert ml to fl oz multiply by 0.033814. To convert the other way, divide by 0.033814
10/16/2023 5:01:09 PM •
Texas...
Answered
on Oct 16, 2023
How can you program games
Do not even go there. The calculator is pretty basic and does not have memory to store instructions. If you want to take up programming ( a worthwhile endeavor) buy a graphing calculator such as a TI 89 itanium, a TI Voyage 200PLT, a TINspire, or a Casio Graphing calculator FX 9860 SD, ClassPad 330, or some top of the line HP calculators (HP 49G+, HP 50 G).
2/1/2023 12:52:48 AM •
Texas...
Answered
on Feb 01, 2023
Exponential key
Ex. for 5^3, press 5, then "yx" (beneath "OFF" button), then the power (3), then press =...
5 --> yx --> 3 --> = --> 125.
Hope this helps!
2/28/2022 2:19:42 PM •
Texas...
Answered
on Feb 28, 2022
The buttons on my TI-30X
I had the same issue.
- Open up the calculator.
- Remove the battery.
- Remove the two screws holding the display section down.
- Carefully pry the button circuit board up and remove it.
- Use an electrical cleaner and lint free cloth to wipe off the button circuit board.
- Re-assemble and test.
For me, cleaning off the button circuit board restored all buttons to working order. When it is disassembled, and after cleaning, you could flip the board, display, etc. up and out of the case and test to see if it works as well.
1/3/2022 7:13:40 PM •
Texas...
Answered
on Jan 03, 2022
How do I convert from
The following examples will demonstrate how to
convert decimals into fractions using the TI-30Xa and TI-30Xa Solar.
Please be aware that TI-30Xa Solar School Edition calculators do not
have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
9/26/2018 5:08:19 AM •
Texas...
Answered
on Sep 26, 2018
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
- Calculate the log 15.32 [LOG] [=] result 1.185258765
- Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Here is a picture of the change sign
Hope it helps
3/8/2018 2:02:23 AM •
Texas...
Answered
on Mar 08, 2018
On my TI 30 XA, I can not get it out of Degree mode.
Why do you want to get out od Degree mode. If you are doing trigonometric calculations, the angle unit is pertinent. If you are not doing trigonometry, it is irrelevant. You say you can cycle through DEG, RAD, GRAD. That is the way to set the angle unit.However, there will always be an indicator on the screen (DEG, RAD, or GRAD).
3/14/2016 9:34:36 PM •
Texas...
Answered
on Mar 14, 2016
