20 Most Recent Brother ML-300 Typewriter Questions & Answers
3answers
How can i type @ .
upper case number 2
7/2/2016 5:38:04 PM • Brother ML-300... • Answered on Jul 02, 2016
Brother Correctronic 360 Word Processing Typewriter, how to remove case to clean keyboard contacts
very hard to do without breaking something. take to repair shop
6/19/2016 7:50:12 PM • Brother ML-300... • Answered on Jun 19, 2016
Striker not working on a Brother ML 300
it could be a broken wire in the harness from the control board to the hammer
3/30/2016 12:45:38 PM • Brother ML-300... • Answered on Mar 30, 2016
Striker stuck; will not strike any keys.
Sounds like the drive clutches are out of sync or a spring has come off the hammer. You will need a trained tech to repair unit. I would go to brother-usa.com to find the nearest service center. Please do not try to take unit apart yourself, too easy to break plastic latches.
3/23/2016 4:03:45 PM • Brother ML-300... • Answered on Mar 23, 2016
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
12/14/2015 7:11:16 PM • Brother ML-300... • Answered on Dec 14, 2015
Ribon will not type
it may have come loose from its post or something in the ribbon drive broke
1/19/2015 5:16:17 AM • Brother ML-300... • Answered on Jan 19, 2015
HOW DO YOU PUT CAPS LOCKS ON
press the cap lock key
1/19/2015 4:54:02 AM • Brother ML-300... • Answered on Jan 19, 2015
How do I type a forward slash on ML-330?
You can only print the symbols that are on the keyboard.
10/22/2014 10:12:40 PM • Brother ML-300... • Answered on Oct 22, 2014
Bought new Brother ML300 will not type anything on the paper, please help!
I would check all the basic stuff first. Is the print wheel locked into position? Is the platen all the way forward? (lever right side) Is the ribbon installed correctly and not cocked up on one side? Do you hear the hammer striking the paper? If you hear the hammer striking the paper, it is a ribbon problem. If you don't hear it, it is a hammer / print wheel problem.
6/24/2014 11:51:38 PM • Brother ML-300... • Answered on Jun 24, 2014
How do I type ' on the brother type writer?
Go to brother.com you can download a manial there. DickyO
5/22/2014 8:14:38 PM • Brother ML-300... • Answered on May 22, 2014
One key contains 3 symbols how do I get all three?
Switch from KB I to KB II. DickyO
5/21/2014 11:59:27 PM • Brother ML-300... • Answered on May 21, 2014
0answers
Striker is stuck
why not put some singer oil. maybe it is all dusted and dirty.. try to clean it once in awhile
4/8/2014 12:46:13 PM • Brother ML-300... • Answered on Apr 08, 2014
0answers
I installed the correction tape and it does not correct
Sounds like you have diagnosed the problem. Remove the correct tape and make sure that it's not the "sticky" type. (it will be hard to unwind if it is). Next try to manually lift the part that's supposed to move to see if it does. If it's sluggish (hard to move) put rags around it to prevent over spray and carefully clean all the moving parts with WD40. Make very sure that the WD40 does not get on any electronic parts! It will also mess up the platen. So, the more rags around the moving parts, the better. I used to work on IBM typewriters, and WD40 sometimes works wonders.
1/2/2014 9:39:33 PM • Brother ML-300... • Answered on Jan 02, 2014
Brother ML-300 Typewriter Logo
179 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
striker not working brother ml 300
  • Office Equipment & Supplies
