20 Most Recent Brother IntelliFAX 1270E Plain Paper Fax Questions & Answers
Brother intellifax 4100e
unplug power cord and re-connect.
2/2/2022 8:52:25 PM • Brother... • Answered on Feb 02, 2022
0answers
Clear brother fax 1270e memory
Unplug it and leave it for 12 hours without any connection and power, it will delete everything inside it. For further info check the manual here: Brother Intellifax 1270e manual
10/27/2014 7:18:14 AM • Brother... • Answered on Oct 27, 2014
Why do we get busy signal for every fax we send?
Check the lines and check the connection, usually it's a problem from your side, There is a nice troubleshooter in the manual so check it out: Brother Intellifax 1270e manual
10/27/2014 7:17:12 AM • Brother... • Answered on Oct 27, 2014
How to cancel a fax in progress on a brother intellifax 1270
If it's from your side just turn the device off, if it's from the other side (if you sent a fax over to someone) then it's in their memory and you can't do anything about it. For further help consult the manual here: Brother Intellifax 1270e manual
10/27/2014 7:16:07 AM • Brother... • Answered on Oct 27, 2014
How to adjust baud rate on brother intellifax 1270e
I have just e-mailed you the manual, if in case you did not get it or anyone else stumbles on this question, you can download it here: Brother Intellifax 1270e manual
10/27/2014 7:15:05 AM • Brother... • Answered on Oct 27, 2014
10answers
"poor line condition'
This is a problem with your voice over ip service. You have to change the setting on your fax machine for example the Baud speed down to 9600, the ECM= off, and the Oversea settings on. Make sure your VoiP ATA is the first thing after your modem or whatever connection you are using for the internet. If you using and old model fax 95% of the time it will not work with VoIP service.
10/14/2014 1:00:55 PM • Brother... • Answered on Oct 14, 2014
How to I get an activity report
In menu, scroll to Fax, enter and scroll to report and configure as your requirement.
9/15/2014 12:48:31 AM • Brother... • Answered on Sep 15, 2014
Why i dont have tone in hand set?
Either its speaker [inside the earpiece]; or the circuit board fault. Contact any service technician. Gopakumar Gopalan Google
6/5/2014 5:14:57 PM • Brother... • Answered on Jun 05, 2014
0answers
Fax in memory 04
Be the first to answer 5/6/2014 3:24:05 AM • Brother... • Posted on May 06, 2014Be the first to answer
2answers
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
4/14/2014 11:59:51 PM • Brother... • Answered on Apr 14, 2014
How to confirm message sent
There is a transmit report which can be auto printed for every fax message sent out. Go to menu, under the fax sub-menu, turn on the transmit report (under report).
4/11/2014 12:28:25 AM • Brother... • Answered on Apr 11, 2014
Brother IntelliFAX 1270E Plain Paper Fax Logo
270 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
am sending fax brother intellifax 2820
  • Office Equipment & Supplies
