20 Most Recent
Brother IntelliFAX 5750e Laser Fax Questions & Answers
I have a Brother intellifax 5750e fax machine. It
There should be either a [Clear] button or an [Options] button on the machine key panel.
Open the front hatch and press the appropriate button. Follow instructions on the LCD display.
11/4/2017 12:29:09 AM •
Brother...
Answered
on Nov 04, 2017
NG: POOR LINE CONDITION / OUT OF MEMORY
You can adjust the Compatibility mode. This adjusts the sensitivity of the machine to interference on the phone line by lowering the transmission speed:
a. Press Menu, 2 (Fax), 0 (Miscellaneous), 1 (Compatibility)
b. Press Up or Down arrow to select "Basic"
c. Press OK.
d. Press Stop/Exit.
e. Try resending the fax.
If the problem continues we recommend you try the unit on another line at the current location or another location. Always restart your machines after you made changes, that way you will see the results.
2/11/2016 6:13:53 PM •
Brother...
Answered
on Feb 11, 2016
SET UP YOUR NAME
Press MENU .... and press 1 (for) General Setup (press right arrow )
and select/press 3 - Station ID (where you can enter your fax number and telephone number and NAME). Enter each and press SET ... and when you're done (after entering your NAME), press the STOP/EXIT button.
1/19/2014 7:58:19 AM •
Brother...
Answered
on Jan 19, 2014
Poor line condition
It's the number of faxes your machine has printed and sent out.
Also you should have a Drum Life Counter.
8/9/2012 2:16:04 PM •
Brother...
Answered
on Aug 09, 2012
My Brother Intellifax 5750e has
take your drum unit/toner out and close door to see if "jam" goes away. if so, look closely on bottom of drum unit in the middle. may be a scrap caught in there. if jam doesn't go away, you may have a piece caught in the fuser which is just b4 paper exits and that area is not easily accessible w/o tearing machine down.
good luck,
razors
7/28/2011 7:28:50 PM •
Brother...
Answered
on Jul 28, 2011
My Brother mfc-665cw will not
Check to see if you can make a call using the fax machine. This error can occur if you have no connection. It can also occur if your line is occupied or busy.
3/2/2011 12:42:13 AM •
Brother...
Answered
on Mar 02, 2011
