20 Most Recent
Brother Disney PE-180D Computerized Sewing Machine Questions & Answers
MY MACHINE NOT READING THE CARD
If card is damaged replace it. Will it read other cards. Can you transfer info to another readable card. Call Brother Online.
Brother PE180D - the bottom
Ive started using pre wound bobbins machine is working perfectly now though had the same problem as you at first
Why won't needle threader go down low enough to meet the hole in the needle?
Try raising the needle so the threader does not have to go so low. The owner's manual should have instructions on what height the needle should be set for using the threader.Here is the information from the owner's manual (Page 20):Auto needle threading deviceNetIf using special threads which wind quickly off thethread spool, attach a net to the spool before using.*Cut the net to match the size of the spool.1 Net2 Thread spool43 Spool pin4 Spool cap1. Guide the thread through the wire loop thread6guide (number "6") and gently pull the threadtowards you.2. Lower the presser foot.3. Lower the needle threader lever until it stops.Hook the thread into the guide and pull itacross to the right.1 Wire loop thread guide2 Needle threader lever3 Guide*The needle threading device CANNOT be usedwhile the needle is LOWERED.4. Push the needle threader lever toward the back.Check to be sure that the hook has passedthrough the eye of the needle and route thethread under the metal guides and the hook.*Pull the thread toward you and check that it isbeing held by the thread hook.==========Here's where you can find the manual instructions:http://www.manualslib.com/manual/355776/Brother-Pe-180d.html?page=20#manual......
NOT READING BROTHER CARD
Is card damaged or dirty. You may need to replace it. It like any other cd or computer accessory. If you soil it forget it.
WHY IS MY THREAD WRAPPING AROUND THE BOBBING IN THE SHUTTLE WHEN I PRESS START
THE BOBBIN HAS ONE METAL PART ON TOP AND ANOTHER PART THAT KEEPS THE BOBBIN FROM MOVING FORWARD. TURN YOUR HAND WHEEL AND WATCH WHICH PLACE DOES THE THREAD GET STUCK. IF IT IS THE ONE ON TOP THEN IT WILL NEED TO BE RAISED SLIGHTLY BY MAKING A PULL WITH NEEDLE NOSE PLIERS. (VERY SLIGHT) IF IT GOES UNDER IT BUT STOPS AT THE AREA WHERE THE LITTLE INDENTATION IS THEN YOU WILL NEED TO LOOSEN ONE OF THE SCREWS AND SLIGHTLY TO ALLOW THE THREAD TO PASS BY. THE THREAD HAS GOT TO PASS THESE AREAS OR YOU WILL NOT SEW.
The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Brother pe180d thread bunching up underneath
try changing the needlerethread the machine top and bobbinmake sure the bobbin is inserted correctly into the bobbin caseand that the bobbin is turned the right waymake sure the thread has not come off the thread take up leverif the machine continues to see bunch thread underneath then the machine may need to be checked to see if some part has becomedamaged or out of alignment
