20 Most Recent
Fossil Watch Style # JR9642 Watch for Men Questions & Answers
Fossil Watch Style #JR9642:The display is black,
There is a reset process for these models. You must short certain contacts to reset the LCD. See your local Certified Master Horologist for help doing this, as shorting the wrong contacts can permanently damage the movement.
Otherwise, if this watch is in warranty, Fossil will generally replace the watch free of charge. I would recommend calling them at 1-800-842-8621.
Even if you cannot find the receipt, they may still replace it based on its age, which is reflected in the serial number.
I hope this helps!
Battery for fossil blu ch-2495
Fossil battery replacement sizes are usually a 2430 (CR2430), 371 (SR920SW), or 377 (SR626SW).
https://www.fossil.com/en-us/******/how-to-change-a-watch-battery
What does the 18 inside a square on the back of my fossil watch mean?
The 18 inside a square on the back of your Fossil watch likely indicates that the watch case is made of 18-karat gold. This is a mark that is used to indicate the purity of gold. 18-karat gold is 75% pure gold and 25% other metals. This mark is typically used on jewelry and watches to indicate the quality of the materials used.
I Have a fossil 10
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
What kind d of battery does a fossil blue am-4065 take?
Hi Cassandra.this is what i found out from the net.Most hybrids are compatible with any CR2430 coin cell battery, which allows them to hold a charge for 4 to 6 months. Swapping in a new coin cell lithium battery can be done easily and in just a few simple steps, plus CR2430 batteries are available from most retailers that sell batteries.
