20 Most Recent Tevion Easily Convert VHS to DVDs-DVD Maker Questions & Answers
Why did I get sound on a recording before, and now I don't?
Most likely because you have changed a setting, causing the sound to be muted or switched the format of the sound. Another cause is a loose cable connection.
5/3/2015 12:47:41 AM • Tevion Easily... • Answered on May 03, 2015
I have a Tevion TLCDD1937 THE DVD WILL NOT EJECT AFTER PRESSING OPEN
There could be a few reasons why your Tevion TLCDD1937 DVD player is not ejecting the disc when you press the open button. Some possible causes include a malfunctioning eject button, a problem with the internal mechanism that opens the disc tray, or a software issue. Try unplugging the device from power and wait few minutes then plug it back in, this may resolve the problem. If the disc is still stuck, try gently pushing it back into the tray and then pressing the eject button again. If the disc still does not eject, you may need to consult the manufacturer for further troubleshooting or consider taking the device to a professional for repair.
1/12/2023 1:03:22 PM • Tevion Televison... • Answered on Jan 12, 2023
My Tevion W42-74G-GB-FTCUP Television won't turn on?
Question edited for clarity. Changed from one long, rambling sentence into lots of sentences. The problem with power cuts is two fold. What caused the outage? If it was a lightning strike, some of the stray voltage 125,000 volts can get as far as the set destroying everything inside it. When the power comes back on, there is often a surge and dirty AC signals until it stabilizes. You may be able to claim for the damage from the electricity utility company. It needs professional diagnosis or just buy new. You can check inside to see if there is a small glass fuse on the power supply. https://www.fixya.com/support/r29790007-repairing_own_television ...
1/3/2023 8:57:16 PM • Tevion Televison... • Answered on Jan 03, 2023
User manual for a TEVION UR 1703
Yes, it is a very little known make. Only scam sites offering it. Universal Remotes were popular in the 80's and 90s, but no one uses Universal remotes these days, you buy a 'facsimile remote', which is an exact copy of your original remote. Google (make of television) model remote replacement This for a Tevion UR4200 on a trusted site https://www.manualslib.com/manual/1253444/Tevion-Ur4200.html https://www.google.com/search?q=TEVION+UR+1703 ..
8/29/2021 3:33:01 PM • Tevion Televison... • Answered on Aug 29, 2021
Have sound, but why no picture?
lts probably the connection issue, it can be a faulty cable cable, improper installation or a bad connection. their may be a video output setting on the device that you must set properly before it will output to the TV. if your display occurred while your your TV is connected to other device like a DVD player, try to change the TV port. if the problem persist you might have an issues with your HDMI cable.
1/10/2021 8:36:57 PM • Tevion Televison... • Answered on Jan 10, 2021
Hi, I need the 3 digit passcode for Tevion TV,DVD. Model number AC19LHC2
Hi, try these combinations- 388, 446, 447, 448, 449, 450, 451 and 452
9/21/2020 8:15:52 AM • Tevion Televison... • Answered on Sep 21, 2020
Looking for a remote control for a Tevion dvr/vcr combo Model 3215, manufactured in 2003.
Chances of buying an original replacement are virtually nil. A universal will only provide basic functions but you should be able to order a compatible remote control online that will enable access to onscreen menus.
5/28/2020 11:01:12 PM • Tevion Televison... • Answered on May 28, 2020
USER MANUAL FOR TEVION CLOCK P1097
I was unable to find the manual but you can refer to the link below for some guidance: http://www.fixya.com/support/t15493826-set_time_tevion_alarm_clock Hope this helps.
10/28/2019 1:46:08 PM • Tevion Televison... • Answered on Oct 28, 2019
I have Tevion DVD VHS o TEV605 but no manual. Can someone tell me how to copy VHS to DVD please.
Converting VHS to DVD with a DVD recorder is quite easy. You need a DVD recorder, a VHS player and your VHS cassette, an RCA or S-Video cable. For more and you can click into the tutorial.
7/11/2019 3:01:49 AM • Tevion Televison... • Answered on Jul 11, 2019
2answers
I bought a Tevion TEV605 vcr/dvd recorder second hand, without remote. Solely for the purpose of copying our old VHS to Dvd. The recording process works fine and will playback in the machine but the dvds cannot be read on other devices. The discs aren't finalising, does anyone know how I can finalise the disc? Or do I need the remote to do this? Thanks in advance
You can finalise any disk on a computer as this will close out the session and make it playable. If you software wont directly let you directly finalise it, then copy the files to the computer and then burn them as a video disk. Nero will do this.
5/24/2019 3:12:19 AM • Tevion Televison... • Answered on May 24, 2019
Where do i find a remote control for my Tevion 19" TV/DVD model 1961?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. https://homenol.blogspot.com/ https://electrohelponline.blogspot.com/ https://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts. /
5/18/2018 5:27:12 PM • Tevion Televison... • Answered on May 18, 2018
Tmy tevion tv needs retuning every few days, what is the proplem?
First check the aerial's cable coaxial(coax) plug/s is/are ok. Poor signal strength can cause this problem - all bad coax connections drop signal strength.
12/29/2017 1:03:09 PM • Tevion Televison... • Answered on Dec 29, 2017
Tevion AX32P1 TV remote where can I get one?
Try ebay. eBayeBay
9/10/2017 2:22:03 AM • Tevion Televison... • Answered on Sep 10, 2017
Codes for urc22b 8 in 1 tv remote for tevion tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
8/26/2017 1:37:58 PM • Tevion Televison... • Answered on Aug 26, 2017
Can you supply a replacement remote control for a Tevion TV 42031d and if so what will it cost Thank you Dennis riley
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://homenol.blogspot.com/ http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
8/26/2017 1:17:03 PM • Tevion Televison... • Answered on Aug 26, 2017
Sky remote code for tevion tv model 43858
7/9/2017 2:42:46 PM • Tevion Televison... • Answered on Jul 09, 2017
Remote control not working GL21A-C3
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
7/9/2017 2:41:28 PM • Tevion Televison... • Answered on Jul 09, 2017
Tune Tv Without Remote tevion tv
Not possible.
7/9/2017 2:40:57 PM • Tevion Televison... • Answered on Jul 09, 2017
Code for tevion 1923dt
7/9/2017 2:40:31 PM • Tevion Televison... • Answered on Jul 09, 2017
Tevion Easily Convert VHS to DVDs-DVD Maker Logo
3 questions posted
Top Tevion Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Larry
Are you a Tevion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tevion Televison & Video
Most Popular Question
did get sound recording before now
  • Televison & Video
