20 Most Recent
Husqvarna Freesia 425 Questions & Answers
Foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
2/26/2019 2:40:01 AM •
Husqvarna...
Answered
on Feb 26, 2019
Bobbin tension Viking Freesia 425
Take a look at www.sewingpartsonline.com and check out bobbin case for your model. Does yours look the same? If so, look up how to adjust bobbin case tension on www.youtube.com.
12/15/2017 4:28:07 PM •
Husqvarna...
Answered
on Dec 15, 2017
Bobbin tension
Difficult to say.
Might try installing a brand new needle.
Remove the top thread, ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midpoint and retest the machine. Tweak the top tension as needed.
Understanding Thread Tension Threads
However, if you believe something is broken in the machine, you may need to order replacement parts.
12/11/2017 7:00:52 PM •
Husqvarna...
Answered
on Dec 11, 2017
UK plug in USA
You need a US to UK transformer if there is not a voltage selector switch on the unit. The motor however may not like being connected to a 60Hz electricity supply. Best contact the manufacturer.
8/3/2014 12:15:55 PM •
Husqvarna...
Answered
on Aug 03, 2014
Digital display is not lighting up
Bad connector, blown board, blown display? Will it stitch in whatever the default stitch is when you do turn on the power to the machine? If so, it's likely just the display. Either way, it's likely to be a take it to the shop fix because opening the case voids the warranty.
5/21/2014 10:58:00 PM •
Husqvarna...
Answered
on May 21, 2014
Bottom tension
What do you mean? Please explain your machine problem. Or you go to expert mechanic shop.
1/6/2014 5:25:49 AM •
Husqvarna...
Answered
on Jan 06, 2014
No reverse or zigzag
There are two different motors for the zigzag and feed mechanism. It is unlikely both failed at the same time. It may be a circuit board or cable problem. You need an expert.
11/21/2013 5:11:32 AM •
Husqvarna...
Answered
on Nov 21, 2013
No manual. how do I change needle position for
When set on a straight stitch using the stitch width button will change the needle position. If you have moved it far to one side you can use the mirror image to shift it to one of 25 positions.
10/13/2013 4:24:24 PM •
Husqvarna...
Answered
on Oct 13, 2013
User manual
This site is very confusing, so I'm not sure if this will get to you, but when you put the bobbin on to wind it with thread, you have to push the little post it sits on over to the right to wind it. When it's full, it stops turning and you have to push it back to the left to get your bobbin off. Hope this helps! Do you have a manual? I'm looking for help with making a button hole desperately!! :(
8/10/2013 7:04:45 PM •
Husqvarna...
Answered
on Aug 10, 2013
I need to replace the
Go to the Husqvarna shop and buy a bulb, they know which one... Might as well bring the machine with you, they will put the bulb in for free, (you will have to pay for the bulb of course...)
2/15/2013 8:59:46 PM •
Husqvarna...
Answered
on Feb 15, 2013
