20 Most Recent
Audiovox 2-Way 14 channel FRS Family Radio Walkie Talkie 2 Mile Radios Questions & Answers
GMRS1100 MANUAL
Download from here: http://www.voxxintl.com/docs/common/GMRS1100/GMRS1100_OM.pdf
Audiovox GMRS1072CH MANUAL
You can download the manual from here: http://www.manualslib.com/manual/355091/Audiovox-Gmrs1072ch.html
Need code frequency list
If you use "Google" and search for FRS, you'll find lots of information on the frequency and codes...
Need Frequency List
CHANNEL
FREQUENCY
01
462.5625
02
462.5875
03
462.6125
04
462.6375
05
462.6625
06
462.6875
07
462.7125
08
467.5625
09
467.5875
10
467.6125
11
467.6375
12
467.6625
13
467.6875
14
467.7125
Sqeal when talk button is pushed
Two known causes of squealing when the radio is put under a load (such as when the PTT is pressed) are a low or bad battery, or being too close to another radio.
I get a skweeel whin
Hi, squeaky sounds a likely caused by bulged capacitor inside the radio or the internal speaker.
If otherwise transmitted is faulty,this will require a skill personnel to handle it, cause it will need opening the transmitter for troubleshooting to detect the faulty component inside the transmitter.
Take care.
Audiovox 2 way family radio charger (for 4
It sounds like you have some corrosion on the terminals. Remove the batteries and with a good light source look at the springs and plates to make sure there is no corrosion. If there is remove it with crocus cloth. Check the batteries also for corrosion. If you find any remove it the same way. If after cleaning everything the batteries still will not charge get new ones as you probably have one or more which are shorted.
Thanks for using FixYa and for the generous rating.
hardrocko
How long do you charge the Audiovox GMRS1072CH
On Audiovox's 9V 250mA ( not certain) suggested charge time is 8hrs, but if you pop the batteries out of the back and stick them into a dedicated battery charger you can usually have fresh batteries in 2-3hrs.
