20 Most Recent
Janome D'cor Excel 5018 Questions & Answers
How to make a button hole with Janome Decor Excel
Hi 'bookwomanran', I don't have a solution but have been wondering the exact same thing! I noticed this question was posted in 2010 and was hoping you may have the solution by now, if so, I'd LOVE to hear it!!! : )
How do i stop geting puckering when sewing
A lot depends upon what you're sewing on, thread, needle, etc. But here are some basics for this problem:
1. Clean your machine! The most common cause of many sewing problems is smutz caught in the bobbin area or tensioning disks.
2. Change your needle and be sure it's the right weight and type for what you're doing. Using a heavyweight needle on lightweight fabric or a 'sharps' needle on knits or an old needle are common causes of puckering.
3. Make sure the thread you're using is appropriate for the fabric and needle. Using light thread on heavy fabric or vice versa can cause puckering as well.
4. Check your tensioning, both upper and bobbin.
5. Take it in and have the timing checked.
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Janome 1100
contact a Janome customer service or a dealer and see if they will sell you one..
Foot for quilting
I would use a foot that can do a zig zag stitch or a blanket stitch
I am trying to make a ruffles look on some tulle.
Try to make two parallel lines of straight sewing on a big stitch, then pull both ends together. this gives the best gather. Tighening the tension to make the thread pull doesn't work as well, although its OK
