20 Most Recent
Juki MO-654DE Mechanical Sewing Machine Questions & Answers
Manual free
hi there
just send to me email , i will send to you instruction manual for MO-654 , as you know this machine is very old , so PDF copy is not a good but not so bad.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
[email protected]
Breaking thread
there could be two things that I can think of right away, one the thread may be old, even if you brought it from the store, two, the needle is in the wrong way or it is the wrong needle .
How do i fix the tension? i've been playing with
Try decreasing your stitch width and this should help. Put your tension dials on 4. Also make sure when you thread your machine your presser foot lever is up to allow you to get your threads through your tension discs properly. To test the tension (usually set at 4 on all 4 knobs) when you thread around the knobs pull the thread on both ends like you're using dental floss around the discs under the knobs so you can feel the pull (tension) on the thread. Let me know if this works for you.
