20 Most Recent
PfaFF Tiptronic 2030 Questions & Answers
My 1222e is frozen
1222E/SE Has "Stopmatic" and disengages the machine for bobbin winding. You can't use the crank and needle is locked. Place your lifter bar to the horizontal level (work turning while needle is down), this will engage the machine.
My 7570 will not run, the light is on but it will not sew
Disconnect the foot control. Turn the handwheel to see if it will turn over freely. Next, power up the machine and press the 'needle down/up' button a few times.. If that works, things are looking promising and the issue is most likely the foot control. If you are able to try your foot control on another Pfaff. If your foot control is not working, most likely it will be the carbon tracer pins inside the foot control. These can be purchased for a few dollars. Skill level to fit them is moderate..... you may break the pins if you do it incorrectly. Alternatively, get a quote for a repairer to do it. Takes 5 minutes.to do.
