20 Most Recent
Simplicity Frontier SL390 Mechanical Sewing Machine Questions & Answers
Does anybody having problem with the machine ? Because whenever i try to sew it keep jamming ? Is there anyway I can fix or whatever ?
Change everything! Rewind the bobbin with new thread and correctly...the thread should be evenly distributed on the bobbin and wound on slowly or it will be too tight. Use a new needle and be sure it is facing the correctly and not backwards ( needles have a front and back). Clean out the bobbin case with the little pipe cleaner brush. Rethread the machine and make sure it hits all the stations ( uptake lever, tension discs, etc...) and make sure the thread is unwinding in the correct direction( clockwise on some machines and counterclockwise on others) check the manual. Exhausting but usually works! Good luck!
Timing if upper and lower loopers
if you look closely at the components of the machine they should have small marks on them that line up with each other or marks on the case. most sewing machines are timed this way the marks have to be lined up on both arms and that should work.
