20 Most Recent Singer 5417 Mechanical Sewing Machine Questions & Answers
Why is my singer 5430csewing machine, doing straight stitch on the top of the material. But zigzag underneath ?
It's not worth fixing. These are higher priced machines with low quality construction.
3/5/2015 3:09:43 AM • Singer 5417... • Answered on Mar 05, 2015
I have a singer 4411 heavy duty and bobbin thread
Either blunt needle or you may have a burr on the needle plate
10/7/2013 7:54:45 PM • Singer 5417... • Answered on Oct 07, 2013
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabricbeing sewedrethread the machine top and bobbinmake sure the bobbin is turned the right way in the bobbin casealso check the top thread tension, if the stitches under the fabricare loose adjust the top thread tension one number or letter higherat a time and sew on a scrap piece of fabric till the stitches look normalhere is a free manualhttp://www.singerco.com/uploads/download/696_5417c.pdf
1/7/2013 6:53:54 PM • Singer 5417... • Answered on Jan 07, 2013
0answers
I have a 5417 C,
You will need a blind stitch foot. I believe that your machine requires a short shank foot. If you already have the foot, you can refer to the Singer sewing book for step by step or go to YouTube for a video of the process (the video uses a different machine but the process is the same) :
http://www.youtube.com/watch?v=jdKe9crSHac
5/18/2011 6:45:36 PM • Singer 5417... • Answered on May 18, 2011
2answers
Singer 301a Bobbin troubles
I just had this problem, too - if you have the manual, check out page 15. If you have removed the throat plate, you need to make sure that the position finger on the bobbin case base enters a notch on the underside of the throat plate. Fixed my problem right away.
4/11/2011 2:00:53 AM • Singer 5417... • Answered on Apr 11, 2011
I need threading instructions for
Why not go to www.singerco.com and download a free manual? You can save it to your computer and enlarge the diagrams for easy viewing. Plus you can print it, if you wish.
3/3/2011 3:55:52 AM • Singer 5417... • Answered on Mar 03, 2011
Singer 5417 not sewing. thread
More than likely it is your top threading. Insert new needle, (flat side facing away from you), totally rethread. Now with presser foot up, pull top thread it should feed easily, now put the presser foot down, the thread should hardly move. This should seat the thread in the tension discs. Hopefully, that is not your timing. You can download a free copy of your manual at www.singerco.com and save it on your computer, then enlarge the diagrams to see everything easily.
12/27/2010 4:09:33 AM • Singer 5417... • Answered on Dec 27, 2010
I have a singer 5417 and it feels like it is
The best thing to do is thoroughly clean the machine and oil it. Take off the throat plate and make sure that there is no lint hiding underneath. I got fooled once, years ago, I thought it was felt that came with the machine, guess what, there was no felt that came with the machine, it was lint packed up so tight that it looked that way. If, I hadn't taken off the throat plate, I would never have seen it and thought that I cleaned it right. Try this and I hope that it helps.
11/22/2010 3:00:21 AM • Singer 5417... • Answered on Nov 22, 2010
4answers
I have a 5417C and
The bobbin case is truly faulty and needs replacement.
To know where the broken needle fell into, suspend a magnet to where you suspected the needle to have fallen, if it is there, the magnet would pick up the broken needle if it is still in the case.
Get a new bobbin case and replace the old one.
Take care
7/1/2010 6:54:11 PM • Singer 5417... • Answered on Jul 01, 2010
2answers
I do not have a manual
go to the store where u buy that machine, or the nearest store of sewing machine. asked for assistance.
6/25/2010 11:20:32 PM • Singer 5417... • Answered on Jun 25, 2010
5417 Mechanical Sewing Machine: ok when my needle goes down it seems to hit someth...
If the needle is not in all the way it will bottom out in the shuttle, or if you bought new needles and accedently got the wrong ones. If the needle does not enter the needle plate far enough to be bottoming out then the machine is out of time. You know i was about to hit post it and I realized I didn't think about, if the needle is bent it will hit the hook. so check those things hope it works out.
5/23/2010 6:46:37 PM • Singer 5417... • Answered on May 23, 2010
Trouble shooting a bobbin threading issue for a Singer 5417C
take the shuttle out and see if there is any thread jammed in
6/20/2009 8:03:52 AM • Singer 5417... • Answered on Jun 20, 2009
The boobin holder came out. How do i out it back in?
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
3/18/2009 2:20:04 PM • Singer 5417... • Answered on Mar 18, 2009
Can I use a vintage singer 161103 zigzagger attachment on a 201 k machine?
No I don't think it will. That attachment is for a 'Slant Shank' machine like a 301. The K on the Sewing machine model number simply means it was built in Scotland. That means it is basically the same as most other 201's.
4/16/2024 5:14:24 PM • Singer Sewing... • Answered 49 minutes ago
Singer 5417 Mechanical Sewing Machine Logo
19 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
  • Sewing Machines
