20 Most Recent
Bell 35170 Cordless Phone Questions & Answers
Phone not charging
If your phone is not charging, then it means there is a problem somewhere. You need to test the battery, charger and phone. Try them out on other devices, the battery might be dead and cannot hold a charge, or the connection port on the phone might be bad also you need to check the charger if it is still working fine. Once you have tested the 3 components, then you will be able to tell where the fault is from and the solution to it is to replace the faulty component.
Hope this advice helped you.
