20 Most Recent
Singer 118 Mechanical Sewing Machine Questions & Answers
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
I removed the presser foot
I just looked at your free manual on the
www.singerco.com site and it looks a little complicated to do, Do you think that maybe downloading the manual and enlarging the diagrams on pages 10 & 11 may help you? If not, call Singer customer service, at 1-800-4singer and ask for some advice. Good luck
11/11/2010 12:38:50 AM •
Singer 118...
Answered
on Nov 11, 2010
My singer inspiration doe not
The individual settings are function based. That is to say that if you select a stitch that is for a straight tack, the machine will not select a sideways pattern.
Look again at your settings, and make sure the right function is set.
Having the correct foot on the machine is also paramount, or you could rip the material or break the needle.
My bobbin housing seems to be messed up. I follow
Ok, if the bottom thread is looping (bottom of fabric) try adjusting your UPPER tension.
Make sure that your thread isn't catching on anything before it reaches your needle, a small snag can cause needles to break.
Can't work lever to raise foot on Singer sewing machine
Presser Foot Release Lever:
First, check if the presser foot release lever is functioning properly. Sometimes, it may be stuck or not engaging correctly. Make sure it moves freely and isn't obstructed.
If it's not working, try slackening the presser foot tension using the dial on top of the machine. If that doesn't help, you might need to adjust the presser bar slightly.
Presser Bar Adjustment:
If the presser bar was loose to begin with, completely slacken off the pressure.
Put the presser foot up using the lever, then slacken off the screw on the bar and adjust the presser bar as needed.
Handwheel Stuck:
If the handwheel is stuck, it could be due to issues with gears, cams, or other internal mechanisms.
Inspect the machine's casing or access panel for any signs of damage, such as broken teeth on gears or misaligned cams.
Thread Take-Up Lever:
If the take-up lever isn't moving up and down even when you manually turn the handwheel, check the hand clutch.
Tighten and adjust the inner portion of the wheel on the right side of your machine and the hand clutch.
If these don't do the job, you might consult Singer's customer service or a repair shot.
My Singer 312 won't go back to a straight stitch. Any ideas? TIA
Inspect the Stitch Width Control: The stitch width control determines how wide the zigzag stitch is. If it's set to a wide zigzag, the machine will remain in that mode. Adjust the stitch width control to the narrowest setting (usually zero) for straight stitching.
Clean and Lubricate: Dust, lint, or debris can interfere with the machine's mechanisms. Turn off the machine, unplug it, and clean the bobbin area, feed dogs, and needle plate. Lubricate any moving parts according to the manufacturer's instructions.
Check the Needle Position: Make sure the needle is centered. If it's off-center, the machine may default to zigzag mode. Adjust the needle position if needed.
Test with a New Needle: A bent or dull needle can cause stitching issues. Replace the needle with a new one and ensure it's compatible with your machine.
Reset the Machine: Turn off the machine, unplug it, and wait for a few minutes. Then, plug it back in and turn it on. This can sometimes reset the internal settings.
Consult the Manual: Refer to your Singer 312 sewing machine's manual for specific troubleshooting steps related to zigzag issues. The manual may provide additional insights or solutions.
The needle and hand wheel on my singer 140q are both jammed. There were no issues with the bobbin or case, no jams there. I can still wind a bobbin on top but once I switch it back to sew the needle and hand wheel are still stuck. No busted belts either.
If both the needle and the hand wheel on your Singer 140Q sewing machine are jammed, it indicates a more serious issue that likely requires attention. Here are some steps you can take to troubleshoot and possibly resolve the problem:
1. Turn Off the Machine: Start by turning off the sewing machine and unplugging it from the power source. This ensures safety while you troubleshoot the issue.
2. Check for Obstructions: Inspect the area around the needle and hand wheel for any obstructions such as broken needles, tangled thread, or debris. Remove any obstructions carefully.
3. Rotate the Hand wheel: Gently try to rotate the hand wheel manually. If it's stuck, avoid forcing it as this could cause further damage. Instead, try to identify what's causing the jam by examining the mechanism closely.
4. Inspect the Bobbin Area: Open the bobbin case and remove the bobbin. Check for any tangles of thread or debris that could be causing the jam. Clean the bobbin area thoroughly.
5. Check the Needle: Remove the needle and inspect it for any damage. Replace the needle if it's bent, dull, or damaged in any way.
6. Oil the Machine: Lubrication is important for smooth operation. Apply a drop of sewing machine oil to the moving parts, such as the hand wheel shaft and other points indicated in your machine's manual.
7. Professional Inspection: If you're unable to resolve the issue on your own, consider taking your sewing machine to a qualified technician for inspection and repair. They can diagnose the problem accurately and perform any necessary repairs.
Attempting to force the machine to work when it's jammed can potentially cause further damage. So, proceed with caution and prioritize safety while troubleshooting the issue.
