20 Most Recent
Singer 5160 Mechanical Sewing Machine Questions & Answers
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Give me diagram how to put bobbin case back in
If you do not have your user's manual, you can download a copy free from the Singer Sewing Machine site. Then take a look on Page 112, and it will show you how to put it back in with drawings.
I lost my manual SInger
You can go to singerco.com and buy one for $15 for a hard cover. They do not offer a free download for this model
My sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Janome Overlocker
Is it a three or four thread machine?
A three thread has little strength used as a seam.
On a four thread,basically, it is a tension problem. You need to ensure that the presser foot is in the up position before threading. The correct path is followed for all threads. You are using good quality thread. Reset the dials to 'normal tension' #3 or 4 .... then slowly work your way from there. The manual should offer advice on which tension to adjust to correct a particular problem.
Can't work lever to raise foot on Singer sewing machine
Presser Foot Release Lever:
First, check if the presser foot release lever is functioning properly. Sometimes, it may be stuck or not engaging correctly. Make sure it moves freely and isn't obstructed.
If it's not working, try slackening the presser foot tension using the dial on top of the machine. If that doesn't help, you might need to adjust the presser bar slightly.
Presser Bar Adjustment:
If the presser bar was loose to begin with, completely slacken off the pressure.
Put the presser foot up using the lever, then slacken off the screw on the bar and adjust the presser bar as needed.
Handwheel Stuck:
If the handwheel is stuck, it could be due to issues with gears, cams, or other internal mechanisms.
Inspect the machine's casing or access panel for any signs of damage, such as broken teeth on gears or misaligned cams.
Thread Take-Up Lever:
If the take-up lever isn't moving up and down even when you manually turn the handwheel, check the hand clutch.
Tighten and adjust the inner portion of the wheel on the right side of your machine and the hand clutch.
If these don't do the job, you might consult Singer's customer service or a repair shot.
My Singer 312 won't go back to a straight stitch. Any ideas? TIA
Inspect the Stitch Width Control: The stitch width control determines how wide the zigzag stitch is. If it's set to a wide zigzag, the machine will remain in that mode. Adjust the stitch width control to the narrowest setting (usually zero) for straight stitching.
Clean and Lubricate: Dust, lint, or debris can interfere with the machine's mechanisms. Turn off the machine, unplug it, and clean the bobbin area, feed dogs, and needle plate. Lubricate any moving parts according to the manufacturer's instructions.
Check the Needle Position: Make sure the needle is centered. If it's off-center, the machine may default to zigzag mode. Adjust the needle position if needed.
Test with a New Needle: A bent or dull needle can cause stitching issues. Replace the needle with a new one and ensure it's compatible with your machine.
Reset the Machine: Turn off the machine, unplug it, and wait for a few minutes. Then, plug it back in and turn it on. This can sometimes reset the internal settings.
Consult the Manual: Refer to your Singer 312 sewing machine's manual for specific troubleshooting steps related to zigzag issues. The manual may provide additional insights or solutions.
The needle and hand wheel on my singer 140q are both jammed. There were no issues with the bobbin or case, no jams there. I can still wind a bobbin on top but once I switch it back to sew the needle and hand wheel are still stuck. No busted belts either.
If both the needle and the hand wheel on your Singer 140Q sewing machine are jammed, it indicates a more serious issue that likely requires attention. Here are some steps you can take to troubleshoot and possibly resolve the problem:
1. Turn Off the Machine: Start by turning off the sewing machine and unplugging it from the power source. This ensures safety while you troubleshoot the issue.
2. Check for Obstructions: Inspect the area around the needle and hand wheel for any obstructions such as broken needles, tangled thread, or debris. Remove any obstructions carefully.
3. Rotate the Hand wheel: Gently try to rotate the hand wheel manually. If it's stuck, avoid forcing it as this could cause further damage. Instead, try to identify what's causing the jam by examining the mechanism closely.
4. Inspect the Bobbin Area: Open the bobbin case and remove the bobbin. Check for any tangles of thread or debris that could be causing the jam. Clean the bobbin area thoroughly.
5. Check the Needle: Remove the needle and inspect it for any damage. Replace the needle if it's bent, dull, or damaged in any way.
6. Oil the Machine: Lubrication is important for smooth operation. Apply a drop of sewing machine oil to the moving parts, such as the hand wheel shaft and other points indicated in your machine's manual.
7. Professional Inspection: If you're unable to resolve the issue on your own, consider taking your sewing machine to a qualified technician for inspection and repair. They can diagnose the problem accurately and perform any necessary repairs.
Attempting to force the machine to work when it's jammed can potentially cause further damage. So, proceed with caution and prioritize safety while troubleshooting the issue.
