20 Most Recent
Singer 1725 Questions & Answers
Horizontal spool holder
Check the local sewing repair shop to see if they can order it for you. You can also search the internet for the manufacturer, model and the word "parts" to see if there are any online suppliers for your machine. If you are creative, you may be able to jerryrig something using a plastic drinking straw, chopstick, or a wooden dowel.
11/30/2015 5:19:55 PM •
Singer 1725
Answered
on Nov 30, 2015
How do you adjust the foot so the fabric goes
the foot only hold fabric against the feed dogs, it's actually the feed dogs that move the fabrichere is a link for a manual for the machine if you don't have one
http://www.singerco.com/uploads/download/691_1725.pdflook in the manual and see if it show where the feed dog lever is so you can check it and see if it's in the right positon, which should be up.check in the manual to see if there is a place to adjust the bar that hold the foot
9/27/2013 2:02:02 AM •
Singer 1725
Answered
on Sep 27, 2013
Do not know how to
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
3/1/2011 12:09:18 PM •
Singer 1725
Answered
on Mar 01, 2011
The thread jams in the
change the needle
clean under the needle plate where the feed dogs are for lint
clean the bobbin are for lint or loose threads
check the thread tension-usually 3 or 4 is good
rethread the machine top thread & bobbin
some machines jam when the thread come off the thread take up lever--I have to watch my mechanical sewing machine for that problem
11/23/2010 6:49:16 PM •
Singer 1725
Answered
on Nov 23, 2010
I sewed a few days
Try the old hair dryer trick, take off the cover, pay attention where the screws go, put some gloves on, then work the reverse lever, button or whatever you have on your machine and your stitch length dial. It may have old grease or oil that needs to soften. Now put your machine back together. Clean and Oil your machine as per your manual. Try rethreading and a new needle before you sew. If you don't have your manual, go to
www.singerco.com and under customer support and download one for free. Good luck. I hope that I have helped you, my advice is free.
11/2/2010 3:46:05 AM •
Singer 1725
Answered
on Nov 02, 2010
