20 Most Recent
Yamata FY811 Mechanical Sewing Machine Questions & Answers
Yamata aFY811
Please let us know your concern so we can help you.
The thread keep bursting as soon as i start to sew although machine is thread properly
Check your thread tension isn't too tight, try on a piece of similar fabric that you are going to use, try sewing a line of stitches, if the thread snaps, change your tension number, then sew another line with your different tension number, try this until you can stitch without the thread snapping, it could be that your bobbin tension is too tight. Can you check your machine manual, it could even be the needle or the thread that's wrong for your fabric. But I would say, check your tension.
Hope this helps.
Bobben timing
with needle in centre stitch position remove bobbin cover needle plate and bobbin assy .turn hand wheel towards you until needle at lowest position, watch the rotating hook, as you turn hand wheel slowly to raise the needle 3/16" the hook should be exactly behind the needle and be just above the eye
Bobbin case
Make sure there is no fabric or thread on the bobbin case shaft. Needle has to be in up position.
